Multicast routing
Cisconew
Below is my task to do. I have configured as per below network topology. Unicast routing is working from receiver to source and vice versa. But multicast routing is not working. I need to know the reasons for this and also the task question also.Please help me.
Task:
Only BGP is running on the routers. Each router is in its own ASN. Only the LAN networks (where servers are connected) and the loopback0 addresses are advertised via BGP using network statements. BGP synchronization is disabled. Transit networks are not advertised. There are no default networks. PIM sparse mode is configured on all interfaces and the RP is set to 3.3.3.3(Router 3) on all routers.
Router 3 is hitting 100% CPU utilization and dropping packets because of the high CPU. What could be causing this?
29 Replies 29
Harold Ritter
Hi @Cisconew ,
Here's probably what is causing the high CPU on the RP (R3).
1. Multicast traffic coming from Source1 is received on R1
2. R1 encapsulates the multicast packets and send them to R3 (PIM register message with source 192.168.12.1) until it receives a PIM register stop message.
3. R3 receives the encapsulated packets from R1 and tries to send a PIM register stop message to 192.168.12.1, as this is the PIM register message source address.
4. R3 doesn't have a route to 192.168.12.1, as transit interfaces are not advertised in BGP and can't send the PIM register stop message to R1
5. it keeps receiving the PIM register messages and need to decapsulate lots of traffic, which is causing the high CPU.
Thank you for your clarification.
R1 is sending Multicast packets from its
G 0/1
interface to R3's Loopback address(3.3.3.3) which is advertised in BGP.
But R3 sends stop message to R1's  physical interface not loopback interface(1.1.1.1).
So, in this case, Is it possible  Receiver  can receive Multicast stream directly from source?
Hi @Cisconew ,
In spite of the situation I described, the receiver should still be able to receive the multicast traffic from the sender.
I think the issue is that your multicast receiver is misconfigured. It should have any multicast configuration, except for the
ip igmp join-group 229.7.7.7
as it is acting as a host not a multicast router.
What is the Solution for the above issue.
Should I advertise transit networks in BGP? OR any other solution?
Hi @Cisconew ,
There is two ways you can fix this issue.
1. use the command
ip pim register-source Loopback0
on R1. You also need to configure
ip pim sparse-mode on lo0
2. Inject the transit subnets in BGP.
I prefer option 1.
I have used option 1
on R1. Also, I have configured
ip pim sparse-mode on R1's lo0.
Then I simulated the ping from source(pinging to 229.7.7.7.But it didn't receive replies.Also, I have checked
sh ip mroute
in R1,R3,R4.
Source#ping 229.7.7.7 repeat 10000
Sending 10000, 100-byte ICMP Echos to 229.7.7.7, timeout is 2 seconds:
R1#sh ip mroute | b Int
Interface state: Interface, Next-Hop or VCD, State/Mode
(*, 229.7.7.7), 00:00:17/stopped, RP 3.3.3.3, flags: SP
Incoming interface: GigabitEthernet0/2, RPF nbr 192.168.14.4
Outgoing interface list: Null
(10.10.10.10, 229.7.7.7), 00:00:17/00:02:42, flags: PT
Incoming interface: GigabitEthernet0/0, RPF nbr 10.10.10.10
(*, 224.0.1.40), 02:45:27/00:02:35, RP 3.3.3.3, flags: SJPL
R3#sh ip mroute | b Int
(*, 224.0.1.40), 02:50:39/00:03:02, RP 3.3.3.3, flags: SJCL
Incoming interface: Null, RPF nbr 0.0.0.0
GigabitEthernet0/3, Forward/Sparse, 02:49:29/00:02:58
GigabitEthernet0/2, Forward/Sparse, 02:50:39/00:03:02
R4#sh ip mroute | b Int
(*, 229.7.7.7), 02:51:08/00:02:58, RP 3.3.3.3, flags: SP
Incoming interface: GigabitEthernet0/3, RPF nbr 192.168.34.3
(*, 224.0.1.40), 02:51:08/00:02:58, RP 3.3.3.3, flags: SJPL
I have wiped out all my old configurations and reconfigured everything.Now multicast is working.
First, I didn't issue
command in R1.so it continuously got register message in
sh ip route
output . After configuring this command, Now register message disappeared and now it is working as expected.
Thank you all for guiding me.
This the output
R1#sh ip mrou | b Int
(*, 228.7.7.7), 00:01:09/stopped, RP 3.3.3.3, flags: SPF
Incoming interface: GigabitEthernet0/1, RPF nbr 192.168.12.2
(10.1.6.6, 228.7.7.7), 00:01:09/00:01:50, flags: FT
Incoming interface: GigabitEthernet0/0, RPF nbr 0.0.0.0, Registering
GigabitEthernet0/2, Forward/Sparse, 00:00:53/00:02:36
(*, 224.0.1.40), 00:12:42/00:02:21, RP 3.3.3.3, flags: SJCL
Loopback0, Forward/Sparse, 00:12:41/00:02:21
After issuing "ip pim register-source Loopback0"" command registering stopped.
(*, 228.7.7.7), 00:04:17/stopped, RP 3.3.3.3, flags: SPF
(10.1.6.6, 228.7.7.7), 00:04:17/00:03:23, flags: FT
GigabitEthernet0/2, Forward/Sparse, 00:04:01/00:03:24
(*, 224.0.1.40), 00:15:50/00:02:12, RP 3.3.3.3, flags: SJCL
Loopback0, Forward/Sparse, 00:15:49/00:02:12
Source#ping 228.7.7.7 repeat 10000
Sending 10000, 100-byte ICMP Echos to 228.7.7.7, timeout is 2 seconds:
Reply to request 67 from 10.4.5.5, 31 ms
Reply to request 68 from 10.4.5.5, 9 ms
Reply to request 68 from 10.4.5.5, 27 ms
Reply to request 69 from 10.4.5.5, 6 ms
Reply to request 69 from 10.4.5.5, 19 ms
Reply to request 70 from 10.4.5.5, 6 ms
Reply to request 71 from 10.4.5.5, 12 m
10.4.5.5
this IP of receiver ?
yes.
That is IP address of Receiver.
Great' glad your lab now working.
Now why I suspect of bgp path' the answer is urpf.
I was thinking and still that path go and back through same interface may make urpf drop multicast.
It need some deep dive.
But later
Have a happy summer
MHM
if I am right
change the RP from R3 to R2 make RP address 2.2.2.2
and check again
let see if I am right.
NOTE:- you must change RP in all routers
5 min it take from me to do lab
I notice you two times
change rp to be 2.2.2.2
lab and success no issue.
If I not reply sorry I watch movie with my family.
Write your Q and i will check later
MHM
Hi @MHM Cisco World ,
You should be able the same lab with R3 as the RP.
@Harold Ritter  as always was right
I config LO in IOU3 (3.3.3.3) and make it
rp-address
and as you can see the multicast is success.
