ā04-15-2013 12:27 PM - edited ā03-04-2019 07:36 PM
hi,
we recently acquire a cisco 2921/K9 router to interface 2 networks
Network 1 : 169.254.XXX.XXX/16 on GigabitEthernet0/0 interface
Network 2 : 192.168.1.XXX/24 on GigabitEthernet0/1 interface
on the network 1 side there is a multicast source (169.254.200.200 destination : 225.0.0.1)
on the network 2 side there is 1 receiver which is not multicast capable(old) but i want it to receive the multicast stream
for the moment we configure the ip multicast-routing and each interface each interface with ip pim sparse-dense-mode then configure the
GigabitEthernet0/1 in order to join the multicast group (using ip igmp static-group 225.0.0.1) and wireshark confirm that the multicast stream on the network 2 side from 169.254.200.200 -> 225.0.0.1
of course the receiver don't the stream, but if i force a "multicast to unicast" process inside the router it shall be ok....
after many hour of internet browsing i found 2 solution :
- NAT, http://netsyshax.wordpress.com/2010/08/23/multicast-to-unicast-and-vice-versa/
- multicast service reflection (Cisco documentation)
the NAT example don't work ,what is the best way to do this task (example if possible
best reagards
Solved! Go to Solution.
ā04-16-2013 05:59 AM
Hi Yoann,
You are almost there.
You need to add the following command on the VIF interface. This is required to attract the multicast stream towards the Vif Interface.
Interface Vif 1
You also need to change the interface on the "ip service reflect" command to specify the input interface.
Interface Vif 1
ip service reflect GigabitEthernet 0/0 destination 225.0.0.0 to 192.168.1.0 mask-len 24 source 10.1.1.2
Hope this helps
ā04-15-2013 03:14 PM
Hi Yoann,
It is quite possible to convert a multicast stream to unicast using the Multicast Service Reflection as described in the following document:
http://www.cisco.com/en/US/docs/ios/ipmulti/configuration/guide/imc_serv_reflect.html#wp1056104
Hope this helps
ā04-16-2013 01:27 AM
hi,
according the Multicast service reflection example (multicast to unicast) i adapt (parmater in bold) to my architecture and the multicast destination address (see attached drawing) and i will try the following configuration next Friday,
best regards
configure terminal
interface GigabitEthernet0/0
ip address 169.254.200.1 255.255.0.0
ip pim sparse-mode
no shutdown
interface GigabitEthernet0/1
ip pim sparse-mode
no shutdown
! Configure the loopback interface for the Service Provider RP
interface loopback 0
ip address 192.168.2.1 255.255.255.255
ip pim sparse-mode
ip pim rp-address 192.168.2.1 mylist override
ip access-list standard mylist permit 225.0.0.4 0.0.0.255
! Configure the Vif1 virtual interface for multicast service reflection
interface Vif1
ip address 10.1.1.1 255.255.255.0
ip pim sparse-mode
ip service reflect Ethernet 0/0 destination 225.0.0.0 to 192.168.1.0 mask-len 24 source 10.1.1.2
end
Hi Yoann,
Interface Vif 1
Interface Vif 1
Hope this helps
ā04-16-2013 10:09 AM
Thanks a lot !
i'll try this next friday and share my tests results for information
best regards
ā04-24-2013 01:22 PM
Ok , it's works !!!
i've only add an command "no shutdown" in vif1 interface (down by default)
tanks a lot !
ā06-18-2013 07:44 AM
Hi Fellas
Can I implement this setup on gns3 dynamips, and how can I test that MRS is working.
ā06-19-2013 01:03 AM
Hi Fella
Please can you let me know if we can test this configuration in gns3...and How did you test it in the real environment. I suppose vlc player?
ā04-15-2013 10:31 PM
I'm not sure of your exact limitations with you router being capable of multicast, but if it is the result of a nbma topology, you may want to look into pim nbma mode, it requires sparse mode on the connection between the routers.
