Multicast Traffic generator
anasubra_2
Can anybody suggest an Multicast Traffic generator(Free window based tool) to test the MVPN solution over MPLS backbone.
Thanking You
Anantha Subramanian Natarajan
12 Replies 12
Harold Ritter
Anantha,
I have used Iperf in the past to test multicast networks.
http://dast.nlanr.net/Projects/Iperf/
Hope this helps,
Hritter,
Thank you very much . But I guess , I am not sure how to use that :) .....I downloaded the source code for windows named iperf-1.7.0-win32 and extracted the same. There is an exe which I when clicked on it opened an DOS prompt for some seconds and automatically closed itself.
Am I looking into the right file ?
Kindly assist me on the same
Thanking You
We used to use things like iTunes and various music & video sharing and similar in class.
The basic exercise was "get multicasting working, and you can listen to music (or watch videos)"
Good Luck
Scott
Anantha,
Once you open your DOS shell, you can start "Iperf --help" to see all the flags and parameters you can set.
Hope this helps,
Anantha,
You need to open a DOS shell and run Iperf with the flags specified in the following documentation.
http://dast.nlanr.net/Projects/Iperf/#multicast
Hope this helps,
Scott,
How was your setup... I have tried sharing Mp3 files over multicast but was never successful
Narayan
Try vlc to stream video or music
regards
John
**Please rate posts you find helpful**
ajaykumar2k1
Find the attached file for windows based multicast tester.
Ajay
Great app.. thank you!
edondurguti
Level 4
Level 4
Run EIGRP if it works it works
or get     VLC and stream a file to a multicast address on a windows/linux machine, then play the multicast from another machine using vlc... ps. just before finishing the stream setup if you use gui add a time to live ttl=12 or something, cuz it's 1 by default.
