Multicast within vrf on 7200's
johnelliot6
Level 2
Level 2
We have network consisting of approx. 8 7200's running LNS/MPLS/BGP and we provide predominantly private networks to clients(Majority of client networks are a mix of Ethernet tails and DSL).
We have received a request from one client to support multicast - Having never implemented multicast, have a few questions:
1. Is is supported/possible to provide multicast within a vrf on 7200's?(From initial investigations, it appears to be)
2. Is it possible to only enable mutilcast in a vrf(i.e. not globally)?
3. Any recommended guides/best pratices?(Googling has revealed nothing really that is similiar to what we want to do)
4. What are the potential ramifications?(Resource overhead, Security implications, anything else?)
Thanks in advance.
Mohamed Sobair
Level 7
Level 7
Answers Inline,
1- Its surly supported in 7200 to run multicast for vrfs.
2- Yes its possible with the command (IP multicast-routing vrf (Name) , this should enable Multicast for Only the Vrf.
3-  Cisco recommends Implementing Source Specific Multicast to optimize Multicast traffic and supports higher bandwidth.
4- There is a lot of Security Recommendations when running Multicast, Here are some Notes to be considered:
a) Implement TTL Scoping for the multicast traffic.
b) RP Protection (Limiting Registration requests, Assigning particular Groups for the RP).
C) The RP Announce if Auto-rp is implemented should be limited using the Scope command.
Mohamed
