Multihoming - As Prepend & Aggregate
subra4u
Hi All,
We have two isp plugged into the same router. Lets say A and B. In the current setup we have X.X.X.124/24 to X.X.X.128/24 published to both the ISPs but with AS prepended to ISP B using route-map. For some reason we see some of the Tier-1 ISPs are preferring ISP B over A to send us the traffic. Now we are looking to do aggregate for ISP B and also AS prepend for one network. Could someone tell me if the following is ok with route-map
ISP A
route-map colt deny 10
match ip address prefix-list network-aggregate
route-map colt permit 20
ISP B
route-map ril deny 10
match ip address prefix-list network-allbut1
route-map ril permit 20
match ip address prefix-list network-prepend
set as-path prepend our_AS our_AS our_AS
ip prefix-list network-aggregate s 5 permit X.X.X.124/22
ip prefix-list network-allbut1 s 5 permit X.X.X.124/24
ip prefix-list network-allbut1 s 10 permit X.X.X.125/24
ip prefix-list network-allbut1 s 15 permit X.X.X.126/24
ip prefix-list network-allbut1 s 20 permit X.X.X.127/24
ip prefix-list network-prepend s 5 permit X.X.X.128/24
Thanks in advance.
subra
6 Replies 6
Edison Ortiz
Subra,
I don't see you sending the aggregate towards ISP B.
On the following route-map:
You are blocking all specifics -- good.
You are prepending .128/24
-- Where is the aggregate? There is an implied deny all..
Edison.
Oops sorry I missed it
It should be
route-map ril permit 30
Otherwise does it look like it will work ok without any issues.
Thanks in advance
Subra
Giuseppe Larosa
Hello Subra,
just to add to Edison's notes:
have you got 4 /24 prefixes from x.x.124.0/24 to x.x.128.0/24 ?
because
x.x.x..124/24
and
x.x.x.128/24 are always the same prefix
x.x.x.0/24
it may be just a typing error in masking your real addresses (and this is safe)
as Edison has noted you need to invoke the right prefix-list in second clause of route-map ril.
Hope to help
Giuseppe
Hi Giuseppe,
You are right. I wanted to mask the original IP address and I ended up typing all wrong.
Actually it should have been
If this is the case then the config i posted should be alright i guess.
"as Edison has noted you need to invoke the right prefix-list in second clause of route-map ril."
i.e. route-map ril permit 30
Will the above statement do any good.
Thanks for pointing it out.
Subra
Hello Subra,
it was clearly a mistyping
I think you need a second clause invoking the prefix-list matching the aggregate.
Also I don't think you need the third empty statement unless there are other routes to be passed to ISPB.
if you have already denied all component routes.
Unless you want to use the empty 30 block to just implicitly match the aggregate route.
I would prefer to match a prefix-list explicitly to have better control leaving an empty block would automatically allow any new prefix you advertise in BGP and also provides a risk for you to pass routes from ISPA to ISPB.
Hope to help
Giuseppe
I would like to send aggregate and the X.X.128.0/24 only to ISP B. So can i have the final config as
Thx in advance
subra
