Multilink configuration
Chennai NOC
Is there any way to configure a multilink bundle with one ethernet drop link and one serial link. If so guide me with configuration steps please
hi your scenario is not clear can u provide more details.
Binoy
dbellaze
Level 4
Level 4
Ethernet is not a point to point link so it does not support PPP encapsulation to participate in multilink. The only exception is PPPoE but that has some other requirements not just PPP.
I don't think you can bond these links with MLP.
Daniel
You cannot do PPP multilink on an ethernet interface as ethernet is a multiaccess network.
HTH, rate if it does
Narayan
A multilink association between a ethernet interface and a serial interface seens to be impossible.
But you can do a kind of multilink association over ethernet interfaces. This kind of "feature" is called EtherChannel. With it you can group ethernet interfaces in a load balance scheme.
See more informations in http://www.cisco.com/warp/public/473/4.html
