MultiLink for point to point connection
ajurado25
We currently have two t1 lines from the corporate office to our warehouse. The t1's on both sides are connected to two wics on 1721 routers. We are attempting to combine the two t1s to get the full 3mbps bandwidth. I tried using the ip cef command but it is not available (even though I'm running IOS 12.1). I am now trying to setup multilink but it just doesn't work. I'm using the same IP scheme on both sides (the current setup has the t1s within the same bridge-group). I've provided my running config.
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Corporate_PTP_Router
enable password xxxxxx
memory-size iomem 25
ip subnet-zero
no ip routing
interface Serial0
ip address 192.168.1.20 255.255.255.0
no ip route-cache
service-module t1 clock source internal
bridge-group 1
interface Serial1
ip address 192.168.1.24 255.255.255.0
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip route-cache
speed auto
bridge-group 1
ip classless
no ip http server
bridge 1 protocol ieee
line con 0
transport input none
line aux 0
line vty 0 4
password xxxxx
login
end
I setup the multilink interface on the corporate side first but I cannot ping the multilink IP. I then proceed to setup the multilink IP on the warehouse side and i can ping that IP address but only from the corporate router.
Any ideas?????
36 Replies 36
Try an IP Plus image of the same version. YOu have an IP Only image.
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
I'm guessing I will have to flash IOS with the IP Plus image. These routers are probably way past their warranty so I don't think I will be able to download any IOS upgrades.
Where in the sh ver do you see the IP only information?
c1700-y-mz.121-3"
The y means IP only for 1700s
If it was sy then that would become IP Plus.
Sankar Nair
That explains the CEF issue. CEF did not become available on the 1720 until 12.3(6). The first ip only image is:
c1700-ipbase-mz.12.3-6
You can look through features such as this (if you have a valid support contract) at:
http://www.cisco.com/kobayashi/support/tac/tools.shtml
That said, multilink ppp is available is your image. and probably the simplest way to go.
See the following for an example. The example uses a pair of cross connected routers, and shows authentication, but you can use your 2 T1s instead and probably don't need authentication since they are not dial-up.:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_configuration_example09186a00800a5efa.shtml
That would make sense to me. On each end, bind the serial interfaces to a dialer, and bridge the dialer.
I'm trying to think what the downsides would be, the only one being some fragmentation issues, but that should be handled with MLPPP reasonably well.
I am sure that would be the simplest.
-colin.
I cannot ping either side of the multilink interfaces. Am I missing something in the config?
Below is the running config for the corporate side router:
version 12.1
ip subnet-zero
no ip routing
interface Multilink1
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial0
no ip route-cache
bridge-group 1
interface Serial1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
no ip route-cache
speed auto
bridge-group 1
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Below is the running config for the warehouse side router:
version 12.1
hostname Warehouse_PTP_Router
ip subnet-zero
no ip routing
ip address 192.168.1.26 255.255.255.0
ppp multilink
multilink-group 1
interface Serial0
ip address 192.168.1.21 255.255.255.0
no ip route-cache
bridge-group 1
interface Serial1
no ip address
encapsulation ppp
no ip route-cache
no fair-queue
ppp multilink
multilink-group 1
no ip route-cache
speed auto
bridge-group 1
ip classless
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Almost there...
You need to change a few things. And the IP addresses you use, are really up to you. But I'm hoping the steps here will give you some idea.
One Caveat, doing these things WILL break your current connectivity, including connectivity to the routers! So proceed at your own risk...
First, place the multilink interfaces in their own subnet for example 192.168.254.0/24 with .1 for HQ and .2 for Warehouse.
Next, and remember, this will break your connectivity, Next, enable 'ip routing' (instead of your current 'no ip routing') on both sides. I would do Warehouse first, then HQ. This way you can make the without locking yourself out entirely...
From HQ router (and you MUST do this from the HQ router), once the Multilink interface comes up, telnet to the Warehouse multilink address and assign a new subnet/address to the warehouse fastethernet, ie 192.168.2.1 /24.
Next place a static/default route on Warehouse:
ip route 0.0.0.0 0.0.0.0 192.168.254.1
Next, place a static route on HQ so it knows what subnets are at the Warehouse:
ip route 192.168.2.0 255.255.255.0 192.168.254.2
At this point, you will be bridging all non-routable traffic on Serial0, and routing IP on Serial 1.
After all that is working, you can remove all bridging references and add the ppp and mulitlink group commands to Serial 0. At this point, you're bundled.
Obviously, you will need to update warehouse computers with the new subnet addressing, including 192.168.2.x, subnet mask of 255.255.255.0 and default gateway of 192.168.2.1.
During my testing the other day I enabled IP routing which caused the routers to sporadically lose connectivity. Is this normal? Even though all IPs on the routers are within the same subnet? Should I be thinking about upgrading the IOS anyways or is this behavior normal?
Until you get all these changes made, and fully convert to a routed approach, including new subnets, no bridging, etc., things will be unstable.
If it were me, I'd convert before introducing any new surprises.
You can search the Bug Toolkit for any known issues related to your current or new IOS.
http://www.cisco.com/cgi-bin/Support/Bugtool/home.pl
Right now the warehouse PCs access the internet throught the corporate firewall. Will changing the IP scheme on the warehouse require additional ip routes?
The HQ router will need a default route to the corporate firewall, in addition to the route to the warehouse subnet I mentioned before.
The Warehouse router will just need its default route to the HQ router multilink IP.
PCs in the warehouse will need to use the Warehouse Fastethernet IP for their default gateway.
And finally, the corporate firewall will need a route to the Warehouse subnet via the HQ Fastethernet IP.
How did it go with your migration?
Everything went smooth. The only thing is the warehouse users still complain about slowness when running one application over the connection (nothing makes them happy). So I guess they will still have to use citrix for that application. Other than that I've been testing the speed I can see a definite improvment. There is only one thing that isn't working. We sometimes use dameware to connect to the warehouse workstations but after the new configuration we lost connection through dameware, even though when can connect via RDP & Citrix. Dameware uses port 6129. Would the router be blocking this port?
Thanks again to everyone for all the input it helped a lot!!
Are there any access-lists of any sort on this router ? Is this application using TCP ?
Sankar Nair
