MultiLink for point to point connection
ajurado25
We currently have two t1 lines from the corporate office to our warehouse. The t1's on both sides are connected to two wics on 1721 routers. We are attempting to combine the two t1s to get the full 3mbps bandwidth. I tried using the ip cef command but it is not available (even though I'm running IOS 12.1). I am now trying to setup multilink but it just doesn't work. I'm using the same IP scheme on both sides (the current setup has the t1s within the same bridge-group). I've provided my running config.
Current configuration:
version 12.1
service timestamps debug uptime
service timestamps log uptime
hostname Corporate_PTP_Router
enable password xxxxxx
memory-size iomem 25
ip subnet-zero
no ip routing
interface Serial0
ip address 192.168.1.20 255.255.255.0
no ip route-cache
service-module t1 clock source internal
bridge-group 1
interface Serial1
ip address 192.168.1.24 255.255.255.0
no ip route-cache
bridge-group 1
interface FastEthernet0
no ip route-cache
speed auto
bridge-group 1
ip classless
no ip http server
bridge 1 protocol ieee
line con 0
transport input none
line aux 0
line vty 0 4
password xxxxx
login
end
I setup the multilink interface on the corporate side first but I cannot ping the multilink IP. I then proceed to setup the multilink IP on the warehouse side and i can ping that IP address but only from the corporate router.
Any ideas?????
36 Replies 36
I'm glad we could help. Be sure to rate any posts you found helpful so other folks will know it was useful information. Helps them navigate the noise, so to speak.
DNS may also need to be updated with your hosts' new IP addresses.
I'm not so familiar with Dameware. I was looking at their website, and they seem to rely on NetBIOS over TCP/IP for some communications, especially name resolution. But I'm not certain.
Do you have any issue connecting to shares across the WAN?
If this is the case, (are some of these boxes Win9x or WinNT?) then you will want to enable WINS on a domain controller, and add the WINS entries to either DHCP or host configuration. I seem to remember you will want to change the netbios node type to hybrid (0x8) if I recall correctly.
Another test, is to verify that you can open port 6129 accross the WAN. You can do this by typing:
"telnet x.x.x.x 6129" where x.x.x.x is the client IP address or devicename as known to dameware. Telnet should tell you if it either can't find the host, or can't open the port.
DNS was updated when i made a change I tested this by having someone connect to a warehouse workstations using RDP from the corporate office.
There doesn't seem to be any issues with the workstations communicating across the WAN to the corporate side. They are able to browse any network shares. All workstations are XP and the domain is a Windows 2000/2003 enviroment only using TCP/IP and DNS. I then tried to connect via dameware to one machine using the IP address but it wouldn't let me connect.
I had also checked to see if port 6129 was open across the WAN to one of the warehouse workstations (using telnet) but it shows as being closed.
I then checked to see if there were any access lists on the routers but there weren't any.
It seems to me that the port is closed or the routers are not forwarding anything using port 6129. This feature was working fine before the change so I know that there isn't any client side firewalls on the warehouse workstations preventing me from connecting, which leads me to think that its something with the router config. I will post the running configs for both routers.
Corporate config:
version 12.1
ip subnet-zero
interface Multilink1
ip address 192.168.254.1 255.255.255.0
no cdp enable
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
interface Serial1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
speed auto
bridge-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.18
ip route 192.168.2.0 255.255.255.0 192.168.254.2
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxxx
login
end
Warehouse config:
version 12.1
hostname Warehouse_PTP_Router
ip subnet-zero
ip address 192.168.254.2 255.255.255.0
no cdp enable
ppp multilink
multilink-group 1
interface Serial0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
interface Serial1
no ip address
encapsulation ppp
no fair-queue
ppp multilink
multilink-group 1
ip address 192.168.2.1 255.255.255.0
speed auto
bridge-group 1
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.254.1
no ip http server
line con 0
line aux 0
line vty 0 4
password xxxxx
login
end
Another question.
Do I need to add a static route to the warehouse router identifying the corporte network?
192.168.1.0 255.255.255.0 192.168.254.1
I ask because I tried to ping from the warehouse router the email server and I did not get any replies.
Thanks.
No, you shouldn't need to. Your default route, 0.0.0.0 0.0.0.0 via 192.168.254.1 should take care of that.
You might try a trace route from the email server to the warehouse computer, and visa versa, to see where this traffic is going.
What is the ip, mask, and default gateway of the email server?
Also, wrt to another post, I don't see anything in these configs that would block dameware nor ICMP. Does ping fail from HQ dameware host to warehouse dameware client as well?
If so, these problems are probably related.
the multilink config should be:
int s0
enc ppp
ppp multi
multilink-group 1
int s1
enc ppp
ppp multi
multilink-group 1
Warehouse_Router
ip routing
int s0
enc ppp
ppp multi
multilink-group 1
int s1
enc ppp
ppp multi
multilink-group 1
ip address 192.168.1.26 255.255.255.0
Actually, the multilink IP needs to be on a different subnet from the Fastethernet interface (currently 192.168.1.0/24) when ip routing is enabled.
