Bookmark
Subscribe
827
multilink interface problem/Question
bhatti.imran
Dear all,
I am first time using the multilink interface for connecting the two remote sites.
And I will deploy these configuration next week on point-to-point link.
I would like to ask from experts that are these configuration works or not. This link will be used for data but prority is VOIP.
Router 1 ( 1760V ) and router 2 Is ( 2611XM)
Configuration of 1760 is
class-map match-all VOIP
match access-group 111
policy-map LLQ
class VOIP
set ip precedence 5
priority 48
class class-default
fair-queue
interface Multilink1
ip address 192.168.234.58 255.255.255.248
service-policy output LLQ
ip tcp header-compression iphc-format
ppp multilink
ppp multilink fragment delay 18
ppp multilink group 1
ip rtp header-compression iphc-format
interface FastEthernet0/0
ip address 172.16.73.1 255.255.255.0
no ip proxy-arp
speed auto
full-duplex
interface Serial0/0
bandwidth 64
no ip address
no ip proxy-arp
encapsulation ppp
no ip route-cache cef
no ip route-cache
no fair-queue
ppp multilink
ip classless
ip route 10.0.0.0 255.0.0.0 192.168.234.57
access-list 111 permit udp any any range 16384 32767
access-list 111 permit tcp any any eq 1720
Now configuration of remote router 2611 XM is
class-map match-all VOIP3
policy-map LLQ3
class VOIP3
set ip precedence 5
bandwidth 48
class class-default
fair-queue
interface Multilink3
ip address 192.168.234.57 255.255.255.248
ppp multilink
ppp multilink fragment delay 20
ppp multilink interleave
ppp multilink group 3
service-policy output LLQ3
interface Serial0/2
bandwidth 64
no ip address
no ip proxy-arp
encapsulation ppp
no ip route-cache
no fair-queue
ppp multilink
ip route 172.16.73.0 255.255.255.0 192.168.234.58
Looking forward for help thanks
7 Replies 7
are these the full configurations of both routers ? I am just asking because you have only one serial interface per router, in which case the multilink would not be necessary. Are you planning to add a second interface, and a second connection between both routers ?
GP
No this is not full configuration.
on cisco 2611 i also have 2 more interfaces and it will connect to other 2 other sites ( not this one ). but there is only one link between ( 1760 and 2611xm).
I have also implement QOS (using LLQ/IP priority) for voice thats why i implemented PPP multilink on serial interface.
My question is after connecting router with the line.
Is this configuration works??
yes, the config will work. Although, as stated, the multilink interface is not necessary if you only have one link between the sites, and causes unnecessary CPU and memory utilization.
GP
I see that you are interested in using TCP,RTP header compression in addition with LFI and LLQ.
In this case if ur much concerned with VOIP traffic i would suggest to give a go with auto qos feature.
That feature is designed only keeping VOIP traffic in mind..
do find the link which talks more about the same..
http://www.cisco.com/en/US/partner/tech/tk543/tk759/technologies_white_paper09186a00801348bc.shtml
your config looks fine except the slight mismatch in the fragment delay on both the sides ..
At ur 1760 its defined as 18 and and in ur 2621 its defined as 20..any specific design consideration behind that ??
regds
As far as i know we cannot use Autoqos function in 1700 series routers , i checked it from below link
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455a3d.html#wp1039216
Secondly i was not able to open below link because it requires athentication ( and i am a normal user in cisco.com)
There is no special reason that i use 18 and 20 fragment delay .
Do it needs to be same in both ends ??
Sorry about the link ,pls do have a look on this ..
http://www.cisco.com/en/US/tech/tk543/tk759/technologies_white_paper09186a00801348bc.shtml
regarding the delay its the time interval specified to place a fragment on the wire.
By default its 30 and u cna tweak it accordingly and i would suggest to keep it either 18 or 20 on both the sides..
regds
amit-singh
Level 8
Level 8
Why are you using multilink for just only a single link. Multilink is used for bundling up multiple links for load-balancing.
Config looks OK and it should work. Just only one this to note is that you rae using different multilink groups on the route. Make it multiink 1 on both the sides.
HTH,
-amit singh
