Multilink PPP Queueing: is it WFQ or FIFO ?
john_fuechsel
Cisco IOS QOS Solutions Configuration Guide, Release 12.4 says WFQ is enabled by default on interfaces configured for Multilink PPP.
But when I "show interface" on the multilink interface I see:
Queueing strategy: fifo
Oddly, the two T1 serial interfaces that are members of the multilink bundle show:
Queueing strategy: weighted fair  [suspended, using FIFO]
"show queueing" doesn't indicate anything for the multilink interface:
FNYRC01#show queueing
Current fair queue configuration:
  Interface           Discard    Dynamic  Reserved  Link    Priority
                      threshold  queues   queues    queues  queues
  Serial0/0:1         64         256      0         8       1
  Serial0/1:1         64         256      0         8       1
Is the "Queueing strategy: fifo" shown for the multilink interface just wrong?  Is WFQ being done only on the physical members of the MLP bundle after MLP has already picked one of the links for that flow?
(At the time of these "show" commands, the link was not congested.)
Thanks in advance for any insight on this issue !
Lei Tian
Hi John,
Can you configure "fair-queue" under MLPPP interface? As far as i know, after you configure mlppp, the member interface will be put in FIFO queue. What you seen on the output of member ports "suspended, using FIFO" is expected.
HTH,
Lei Tian
Thanks, Lei Tian !
I finally got into the lab to try this out and found that coding "fair-queue" on the MLPPP interface gives me what I'm looking for.
I guess the documentation is just incorrect about the default queueing on that kind of interface.
Now I have:
CW-Test-Router#show int mu1
Multilink1 is up, line protocol is up
  Hardware is multilink group interface
  Description: Multi-T1 bundle
  Internet address is 172.16.171.113/30
  MTU 1500 bytes, BW 3072 Kbit, DLY 100000 usec,
  Encapsulation PPP, LCP Open, multilink Open
  Open: IPCP, loopback not set
  Keepalive set (10 sec)
  DTR is pulsed for 2 seconds on reset
  Last input 00:00:14, output never, output hang never
  Last clearing of "show interface" counters 00:13:30
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/1/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 2304 kilobits/sec
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 0 bits/sec, 0 packets/sec
     4 packets input, 56 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4 packets output, 80 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 carrier transitions
and:
CW-Test-Router#show queueing
  Multilink1          64         256      0         8       1
Many thanks for your reply!
seems to be something missing, even decreasing bandwidth from E1, it is still fifo, on both MLP and Virtual-template... Cisco might need to rectify their document.
