Multilink problem between cisco and Nortel router
kumar94437
Sir,
I have done multilink between cisco and nortel router.Its working fine.Some times multilink is up but not passing packets.If i give shutdown and no shutdown to multilink found packets are passing.
1.Any additional commands are there to multilink cisco and nortel router.What may be the problem.
Senthil
7 Replies 7
Giuseppe Larosa
Hello Senthil,
this adds information to your previous thread.
PPP multilink is a standard so it should work and no special commands should be given to improve the behaviour
what is the PPP state in sh ppp multilink when user traffic doe not pass over it ?
the shut/ no shut resets the PPP state machine.
Hope to help
Giuseppe
Dear sir,
Output of Show ppp multilink while multilink up but not pinging is\
Multilink2, bundle name is ROUTER
  Bundle up for 20:58:58
  Bundle is Distributed
  0 lost fragments, 1686 reordered, 0 unassigned
  0 discarded, 0 lost received, 1/255 load
  0xBB2A4 received sequence, 0x64C109 sent sequence
  Member links: 16 active, 0 inactive (max not set, min not set)
    Se1/1/0/1:0, since 11:08:36, no frags rcvd
    Se1/1/0/2:0, since 11:08:36, no frags rcvd
    Se1/1/0/3:0, since 11:08:36, no frags rcvd
    Se1/1/0/4:0, since 11:08:36, no frags rcvd
   Se1/1/0/5:0, since 11:08:36, no frags rcvd
    Se1/1/0/6:0, since 11:08:36, no frags rcvd
    Se1/1/0/7:0, since 11:08:36, no frags rcvd
    Se1/1/0/8:0, since 11:08:36, no frags rcvd
    Se1/1/0/9:0, since 11:08:36, no frags rcvd
    Se1/1/0/10:0, since 11:08:36, no frags rcvd
    Se1/1/0/11:0, since 11:08:36, no frags rcvd
    Se1/1/0/12:0, since 11:08:36, no frags rcvd
    Se1/1/0/13:0, since 11:08:36, no frags rcvd
    Se1/1/0/14:0, since 11:08:36, no frags rcvd
    Se1/1/0/15:0, since 11:08:36, no frags rcvd
    Se1/1/0/16:0, since 11:08:36, no frags rcvd
Thanks and Regards,
senthil
Sir,SH ppp multilink output of another multilink
Multilink1, bundle name is RTR
  Bundle up for 4d12h
  22 lost fragments, 1183131 reordered, 0 unassigned
  5 discarded, 7 lost received, 1/255 load
  0x4ACD received sequence, 0x282B09 sent sequence
  Member links: 2 active, 0 inactive (max not set, min not set)
    Serial5/1:0, since 00:15:47, last rcvd seq 004ACC
    Serial3/3:0, since 05:43:23, last rcvd seq 004ACB.
Thanks and Regards,
Senthil
Eric Boadu
Kumar, make sure UDP traffic is enable on Nortel router. Some of the nortel routers don't handle UDP multilink traffic well. Look into pim or igmp forwarding solutions for your Nortel router.
Thx,
Eric
Sir,i am not expert in nortel router.how to check udp is enabled .
Thanks and Regards,
Senthil
Eric Boadu
please provide your Nortel Router model and current version.
Thx,
Eric
Sir,
Nortel secure 3120 router.
OPAL SW VERSION:        r9.2
Thanks and Regards,
Senthil
