Multiple GRE Tunnels with same source and destination address
Djule2804
We have the following problem :
We have two sites, site A and site B which are interconnected as following :
(Site A)--Router A---Firewall A---------WAN--------Firewall B---Router B-----(Site B)
The two routers are 3825 Cisco Routers.
On each of theses routers, there are multiple VRF created in order to separate user traffic.
Each Cisco router is interconnected with its firewall by an ip adress in the global routing table.
We wanted to create as much GRE tunnel as VRF.However, all the GRE tunnel must have the same source and destination address which is the address of the interface linked to the firewall (address in the global routing table).
Here is an exemple of our configuration :
interface Tunnel 1
ip vrf forwarding vrf_1
ip address 10.0.0.1 255.255.255.0
keepalive 10 3
tunnel destination GigabitEthernet 0/1
tunnel destination 93.2.3.2
interface Tunnel 2
ip vrf forwarding vrf_2
ip address 11.0.0.1 255.255.255.0
keepalive 10 3
interface Tunnel 3
ip vrf forwarding vrf_3
keepalive 10 3
When we set up a unique Tunnel, it works very well (Interfave Tunnel up).
But as soon as we create another tunnel with the same source and destination address, these tunnels fall down.
So, is it impossible to create Tunnels with the same source and destination address? So is there any other solution to fix our problem?
Thanks you very much for your responses
Best Regards
paolo bevilacqua
Use "tunnel key".
paolo bevilacqua
Use "tunnel key".
Thank you very much! This command solved our problem.
Mlex1
Добрый день! у меня такое проблема я настроил gre T0 между 4 роутер туннели работает они видит себя толка по один стороны. у меня 3 роутера по середине 1 роутер вот по этой картинкиdb0e71b58b.png
Wish all the best
