Multiple IPs of VLAN
                    can we assigned Multiple IPs on Single VLAN. by using the IP address X.X.X.X X.X.X.X secondary
My query is
VLan 10
I had different IP for different user on VLAN 10
10.10.10.1/24 for 1st floor
10.10.20.1/24 for 2nd floor
10.10.30.1/24 for 3rd floor
simliarly up to 10 floor.
can all these IP will communicate with same VLAN 10..  only  Primary IP assigned in VLAN 10 P will work r and est of other user cant able to communicate? or all the users will able to communicate with out disturbance..
John Blakley
Yes you can. It works fine. You'd need to add your other subnets as a secondary address, but it would look something like this:
int vlan 10
ip address 10.10.10.1 255.255.255.0
ip address 10.10.20.1 255.255.255.0 secondary
ip address 10.10.30.1 255.255.255.0 secondary
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
mfurnival
Level 4
Level 4
It is a bit of a weird way of doing things though. More standard way to do things is to have a separate VLAN for each floor, trunked interfaces down to each floor switch and L3 SVI for each VLAN configured on the switch.
I agree with John. It works fine.
U can have many subnets as u want.
Inayath.
