Multiple ISP configuration in ASA 5515-x
Hi everyone today i need use multiple ISP simultaneously in a Cisco ASA 5515-x, have configure two default routes, the primary with metric 9 and the second with metric 10, and the nat are configured and is working without problems.
That i'm trying to do is use both ISP simultaneously and i think that will be possible using a route-map for route same network through my secondary ISP, but in ASA the route-map is not equal as the common cisco routers.
Somebody can tell me if that is possible?
bgp possible too in ASA ios 9.4
if there are private AS and PI network
