Multiple Subnets of a /24 BGP
Steven Peterson
We have 2 non contiguous /24 from ARIN, our network is broken into 3 major sections, one has its own /24 the other 2 split one as follows
204.138.16x.0 /24
     204.138.16x.0 /25 --> 204.138.16x.140
     204.138.16x.128 /26 Directly connected to router
     204.138.16x.192 /26 --> 204.138.16x.170
Additonaly in the range directly attached to the router are a mix of firewalls and vpn endpoints.
here are the vitals in my bgp config
network 204.138.16x.0
  aggregate-address 204.138.16x.0 255.255.255.0
  redistribute static route-map rm_redist_ok
the prefix list in the route-map lists our subnets, that we want to redistribute
then denys everything else
now we have this up and advertising, the route to /24 in question shows up in the table and a trace route get to the cisco router but not beyond it
this includes to addresses in the directly connected subnet as well as ones routed through it.
The router/firewalls behind my cisco edge are openbsd based.
Any idea what I am doing wrong? I am willing to send the full config via private message I would prefer not posting my full ip blocks to make it harder for them to be harvested by spamers.
Dennis Mink
So can you actually ping  anything in the 204.138.16x.128 /26 range, most importantly, the router's
IP address in this range?  if so that would mean routing on this subnets wiorks both ways end to end.
Please remember to rate useful posts, by clicking on the stars below.
Hi Steven,
few things i can think of....
Do the firewallls,vpn devices have a default route back to this router?  Maybe its the return traffic that is not getting back. As you said you can get to the router from outside but it doesnt go any further. Also, maybe you need to check the firewall routing as well.
Also , if you are going to redis all the more specif prefixs into the BGP table in this case then you dont need to put in the network A.B.C.D because you are  going to advertise the summary route anyway for those prefixes.
Does this give you any direction?
HTH,
Kishore
I checked the traffic flow and the default route is set on the firewall/routers behind the edge device.
I can ping the edge router from a from a device behind any of the firewalls. additonaly I can get the the edge routers telnet and ssh from behind any of the firewalls.
I tried removing the network 204.138.16x.0 statement and at that point we stopped advertising the route. I waited a few minutes to see if this was just temporary. the route did not get readvertised.
once I readded the network 204.138.16x.0, the route was advertised again.
Hi ,
So , if you take out the network command your config would look like this
router bgp
...and you are not seeing 204.138.16x.0/24 getting advertised , the reason is because you have an aggregate command but you dont have atleast one specific route in the BGP table.
The  network command works because you must have had atleast 1 address in that /24  range in your routing table or you must have configured a Null 0 route.
Can  you please paste the  "sh ip bgp neigbor   advertised-routes"? and also the route-map and prefixz-list
Just being pedantic, the filters and ACL's are all fine on the firewall and the internal devices right?
