My 1861 Router is Showing like this how to trouble shoot this Problem
Hi All,
My Router is showing like this can any one explain me what it is and why its showing like this
and every time its going to Rmon mode some times going to Normal mode
how to tourble shoot this problem,
is the problem is flash or some thing els explain me and why its showing like this (Readonly ROMMON initialized)
The output is shown like this
System Bootstrap, Version 12.4(11r)XW3, RELEASE SOFTWARE (fc1)
Copyright (c) 2007 by cisco Systems, Inc.
C1860 series platform with 262144 Kbytes of main memory
program load complete, entry point: 0x80015000, size: 0xb700
program load complete, entry point: 0x80020000, size: 0x1dac7e0
Self decompressing the image : ################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
Bad FIO_0 EC220 vendor device id 0xFFFFFFFF
                0X00003960 Onboard Ethernet
                0X000F3BB0 public buffer pools
                0X00703000 public particle pools
TOTAL:          0X007FA510
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 7Mb.
adjusted iome size up to minimum size of: 0X00C00000
Using 4 percent iomem. [12Mb/256Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C1861 Software (C1861-SPSERVICESK9-M), Version 12.4(11)XW6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Wed 13-Feb-08 16:03 by prod_rel_team
Image text-base: 0x800200EC, data-base: 0x82C7C574
04:34:37 UTC Sat Apr 7 2012: Unexpected exception to CPU: vector 200, PC = 0x80444C24, LR = 0x80444C08
-Traceback= 0x80444C24 0x80444C08 0x80439DA0 0x80437BE0 0x800379F8 0x825B289C 0x810F8858 0x810F8B4C 0x80227A6C 0x8022A36C
CPU Register Context:
MSR = 0x00049030  CR  = 0x22008084  CTR = 0x00000000  XER   = 0x20000000
R0  = 0x00000000  R1  = 0x84CAE0C0  R2  = 0xFFF5FFF5  R3    = 0x00001388
R4  = 0x00000000  R5  = 0x84FAE234  R6  = 0x00000F9F  R7    = 0x001312D0
R8  = 0x431BDE83  R9  = 0x70020004  R10 = 0x211100BD  R11   = 0x00000000
R12 = 0x84FAD030  R13 = 0xFFF5696C  R14 = 0x810F8AEC  R15   = 0x00000000
R16 = 0x00000000  R17 = 0x00000000  R18 = 0x00000000  R19   = 0x00000000
R20 = 0x00000000  R21 = 0x00000000  R22 = 0x00000000  R23   = 0x84CAE121
R24 = 0x84410830  R25 = 0x84CAE120  R26 = 0x00000000  R27   = 0x84CAE121
R28 = 0x00000000  R29 = 0x0000F800  R30 = 0x0000001F  R31   = 0x84FA8030
Writing crashinfo to flash:crashinfo_20120407-043437
=== Flushing messages (04:34:37 UTC Sat Apr 7 2012) ===
Queued messages:
No warm reboot Storage
*** System received a Bus Error exception ***
signal= 0xa, code= 0x200, context= 0x84636be0
PC = 0x80444c24, Vector = 0x200, SP = 0x84cae0c0
rommon 1 >
Leo Laohoo
If you have any modules or WIC cards installed, remove them from the router and try again.
If the problem persists without the NM modules or WIC cards then try a different IOS version.  Hopefully NOT the "XW" train.
there is no WIC CARD installed on this router what should i do for this router help to trouble shoot this problem
paolo bevilacqua
Already replied in another thread:
https://supportforums.cisco.com/message/3603500
Please do not open duplicates.
gephelps
The exception vector in this output is 200. If this happens repeatedly then I would look at replacing the chassis.
