my ip public don't receive ping and my ip lan
lcr412001
Ping same range red
Router#ping 10.195.1.59
Sending 5, 100-byte ICMP Echos to 10.195.1.59, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#ping 10.195.1.58
Sending 5, 100-byte ICMP Echos to 10.195.1.58, timeout is 2 seconds:
Router#ping 10.195.1.57
Sending 5, 100-byte ICMP Echos to 10.195.1.57, timeout is 2 seconds:
ping public wan ip
Router#ping 200.26.191.140
Sending 5, 100-byte ICMP Echos to 200.26.191.140, timeout is 2 seconds:
Router#ping 200.26.191.141
Sending 5, 100-byte ICMP Echos to 200.26.191.141, timeout is 2 seconds:
Router#ping 200.26.191.139
Sending 5, 100-byte ICMP Echos to 200.26.191.139, timeout is 2 seconds:
Router#sh interfaces
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 6400.f18c.3960 (bia 6400.f18c.3960
Internet address is 200.26.191.139/24
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is XON, input flow-control is XON
Last input 00:00:25, output 00:00:07, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
793 packets input, 99470 bytes, 0 no buffer
Received 791 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
980 packets output, 101998 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
1 lost carrier, 0 no carrier, 0 pause output
GigabitEthernet0/1 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is 6400.f18c.3961 (bia 6400.f18c.3961
Internet address is 10.195.1.60/24
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:05, output hang never
Input queue: 0/75/26/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 166000 bits/sec, 359 packets/sec
5 minute output rate 1000 bits/sec, 0 packets/sec
2043695 packets input, 122913923 bytes, 38 no buffer
Received 2043512 broadcasts, 0 runts, 0 giants, 5 throttles
110 input errors, 0 CRC, 0 frame, 110 overrun, 0 ignored
0 watchdog, 650 multicast, 0 pause input
1109 packets output, 149688 bytes, 0 underruns
nagasheshu2010
Please explain what exactly is your issue.
Sheshu.
pwwiddicombe
Level 4
Level 4
Several things here - you are pinging internal, and Internet addresses.
Your router will have a default ID that it pings from.  If that happens to be the internal address, you won't be able to get a reply from the Internet connection - the 10.x.x.x address range is non-routable over the internet as a standard.  Try with an extended ping, and SPECIFY the 200.26.191.139 address when you try to ping externally.
Similarly, when pinging internal addresses, specify the 10. local interface address.  It's possible the internal devices don't have your router here as the default gateway, but if you SPECIFY the local interface, they don't need a formal gateway.
The other thing - are you sure all the addresses you are trying to get to actually exist?  Any chance the configuration on your router has something else that doesn't restrict these from getting through?
