N7k10 l2 loop detection
x03
Hi everybody.
We have a Cisco chassis switch C7010 (NXOS 6.2.16) as a core of the Ethernet lan. Where we aggregate trunk ports from all Ethernet nodes.
But in there switch no have classic "loop detection" function.
How i understand that is possible realize by STP, which is enable by default there.
Now i enable mac address-table notification and change the logging level and starting receive this:
2017 Jul 24 13:00:08 swcore %L2FM-4-L2FM_MAC_MOVE: Mac bcad.286d.0e83 in vlan 1035 has moved from Eth10/27 to Eth10/9
1) Main aim of my questions is a detect+block parasites Broadcast traffic borned by Loops on other switches connected with trunks to N7K.
How i think, it can be solved with 'stp Loopguard enable' and 'stp bpdufilter enable'
2) And i have access mode ports on N7k and need realize Loop-Detection for all access ports.
3) Also sometimes i got a message:
2017 Jul 21 15:30:59 swcore %$ VDC-1 %$ %STP-2-BLOCK_PVID_LOCAL: Blocking Ethernet1/13 on VLAN1005. Inconsistent local vlan.
2017 Jul 21 15:30:56 swcore %$ VDC-1 %$ %STP-2-UNBLOCK_CONSIST_PORT: Unblocking port Ethernet1/13 on VLAN1005. Port consistency restored.
Event:E_DEBUG, length:113, at 212383 usecs after Fri Jul 21 16:06:31 2017
[105] stp_sstp_bad_pvid() port Eth1/13 SSTP BPDU rcvd on VLAN 1005, VLAN tag 211 making local port inconsistent
Tag 211 is not configured on N7K. And this is no my tag.
As i know this may be reason is a different configs on trunk ports. How i understand this can be solve by "bpdufilter enable" on Int eth1/13
How can i configure STP as classical loop-detection on base-mac-addr (I Need block vlan, don't need block eth port).
PS. We do not use STP tolopogy for lan sw.
_
Sorry for my bad Eng.
Regards.
ajay chauhan
Level 7
Level 7
I am not sure what topology you are using in network . Please confirm -
are you using VPC ?
Are you using port channel to connect nexus 7k ? what is other end device ?
Do you have STP on ?
Most likely loop will be caused when you turn off STP.
Ajay
We use N7k as a Metro-Ethernet core without circle topology.
So it's classical 'star' topology like as N7k - aggregation layer - access layer
- no vpc
- Yes, we use port-channel, but not for aggregation layer.
For port-channel we don't need loop detection.
As i understand STP is enable on all vlan by default (STP doesn't enabled by me specially)
sw-core# sh spanning-tree
VLAN0002
Spanning tree enabled protocol rstp
What anybody thinks?
__
