NACLs and Multicast
jthomp7626
I am trying to see if the following can work.
access-list extended Out
     permit udp host 239.10.10.1 range 1020 1030 any
access-list extended In
     permit udp any host 239.10.10.1 range 1020 1030
int vlan 10
     ip access-group Out out
     ip access-group In in
So far no luck. Any ideas? thank you
Richard Burts
Especially as far as your Out access list is concerned - the source address of an IP packet will never the be multicast address. The source is always a unicast host.
Rick
Rick
margalla
As already said, a multicast address shouled never be a source address so the Out ACL is wrong on its face.
The In ACL should allow udp traffic to destinaton 239.10.10.1 and ports 1020-1030 into the router on vlan 10. Is that what you are trying to do?
