NAT and ACL lists
grant
I have a cisco 1841 router. This connects our organisation to the internet via a satellite link. We are using NAT.  I am trying to limit users on our lan to only access www, icmp, dns ports through the router thus preventing  any excess traffic. Here is a copy of the config that is working. When I try to limit access to ports user can no longer access the internet.
service password-encryption
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
clock timezone GMT 2
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip host datum 2001 10.1.1.1
ip name-server 217.15.112.170
ip name-server 217.15.112.171
ftp-server topdir ptjit
interface FastEthernet0/0
description LAN BACKBONE
ip address 172.17.0.11 255.255.255.0
ip flow ingress
ip nat inside
ip route-cache flow
duplex auto
speed auto
fair-queue
interface FastEthernet0/1
description WAN NETWORK
ip address x.x.x.90 255.255.255.252
ip nat outside
duplex auto
speed auto
fair-queue
ip classless
ip route 0.0.0.0 0.0.0.0 x.x.x.89 name BSATT
ip flow-export source FastEthernet0/0
ip flow-export version 9
ip flow-export destination 172.17.8.99 2055
no ip http server
ip http authentication local
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat translation tcp-timeout 900
ip nat translation max-entries 1800
ip nat inside source list 102 interface FastEthernet0/1 overload
ip nat inside source static tcp 172.17.8.50 8080 interface FastEthernet0/1 8080
ip nat inside source static tcp 172.17.8.50 445 interface FastEthernet0/1 445
ip nat inside source static tcp 172.17.8.50 139 interface FastEthernet0/1 139
ip nat inside source static tcp 172.17.8.50 135 interface FastEthernet0/1 135
ip nat inside source static tcp 172.17.0.16 22 interface FastEthernet0/1 22
ip nat inside source static tcp 172.17.8.20 46520 interface FastEthernet0/1 46520
ip nat inside source static tcp 172.17.8.23 46523 interface FastEthernet0/1 46523
ip nat inside source static tcp 172.17.0.16 25 interface FastEthernet0/1 25
ip nat inside source static udp 172.17.0.16 25 interface FastEthernet0/1 25
ip nat inside source static tcp 172.17.8.50 6001 interface FastEthernet0/1 6001
ip nat inside source static tcp 172.17.8.50 6002 interface FastEthernet0/1 6002
ip nat inside source static tcp 172.17.8.50 6004 interface FastEthernet0/1 6004
ip nat inside source static tcp 172.17.8.50 443 interface FastEthernet0/1 443
ip nat inside source static tcp 172.17.8.50 593 interface FastEthernet0/1 593
ip nat inside source static tcp 172.17.8.50 80 interface FastEthernet0/1 80
access-list 102 permit ip 172.17.0.0 0.0.255.255 any
cdp timer 10
control-plane
line con 0
login local
line aux 0
no exec
transport input all
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
login
ntp clock-period 17178356
ntp server 64.147.116.229
end
14 Replies 14
cadet alain
This is static PAT or port forwarding and it permits users on the internet to access a service on a LAN machine.
What is the subnet of your users is 172.17.0.0/24 ? because this is what you are NAT overloading for and in your static PAT I see 172.17.8.50
I don't see in your config any ACL restricting your users from accessing the internet.
You can do this with Zone-based firewall if you've got 12.4(6)T or higher.
Regards.
Alain.
Hi Alain
My Lan is 172.17.0.0 /16 . 172.17.0.0 /24 is used for back bone. 8.50 is my mail server. I am running software release 12.4
access-list 101 permit udp 172.17.0.0 0.0.255.255 any eq 53
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 53
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 20
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 21
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 23
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 25
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 80
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 143
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 443
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 465
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 587
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 993
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 995
access-list 101 permit icmp any 172.17.0.0 0.0.255.255
access-list 102 permit tcp any 172.17.0.0 0.0.255.255 established
ip access-group 101 out
ip access-group 102 in
Thanks Grant
It can't work this way because packets leaving this interface are natted and so the only match is the implicit deny at the end of ACL.
One remark also:
this is really not secure and not stateful.
Regards.
Alain.
Hi Alain
Is there a way to apply the ACL on either of the interfaces or should I be looking at an alternative way of  controling which ports are open.
The access-list 102 permit tcp any 172.17.0.0 0.0.255.255 established was just to try and get it working I wanted to only allow those specific ports coming in. I read a number of articles to get to where I have but have been struggling for some time with this.
Let me know your thoughts
thanks
jgraafmans
NAT is done before matching the access-list. You can place access-list 101 incoming on f0/0 or change the source addresses of the access-list to the IP address of the f0/1 interface. In both cases you also have to change the destination of access-list 102 to the IP address of the f0/1 interface
I will give this a go and post my updated ACL.
thanks for the suggestions.
grant
I have put the following config in. This is now controlling outgoing access to the ports. If I try and put anything to control incoming connections internet goes offline. With this configuration I cannot access my mail servers web address from the LAN and no incoming or outgoing mail goes through. Any suggestions.
access-list 101 permit udp 172.17.0.0 0.0.255.255 any eq 123
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 22
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq 8080
access-list 101 permit icmp 172.17.0.0 0.0.255.255 any
access-list 101 permit ip any host 65.88.254.131
interface fastethernet0/0
ip access-group 101 in
grant
After some testing I have found I cannot access my mail server 172.17.8.50 on port 443 from the internet with the ACL activated.
I also cannot access port 25 or port 80.There is obviously something that I am missing here just not sure what yet. Any ideas.
Thanks g
Do you still have access-list 102 applied inbound on interface f0/1?
What if you remove this access-list from the interface so you can be sure packets incoming on interface f0/1 are always permitted?
You could also place log after the access-list so you can log which access-list rules are being matched.
I have left access-list 102 in place as that is part of the nat. If I remove 102 no traffic passes. If I add 103 not traffic passes.
With 101 and 102 applied I can access internet from any machine but cannot access any of the services through nat port 25 or 443 or 80. from the internet or from the lan. I tried adding access-list with the external ip's on fa0/1 and still could not. I can add the log at the end but have been unable to see where I can view this log. Thanks for the suggestions.
Merry Christmas
g
I just realized that your access-list has the established keyword which is indicating that a session must have been initiated from the inside before (returning) traffic is permitted which is not the case if someone from the internet is initiating a connection to for example the mail server.
It is better to use different access-lists for NAT and access control
With my question I meant: Do you still have ip access-group 102 in configured under interface f0/1 but from your previous post I presume you do.
For testing it is best to remove this command totally because without this command all traffic on that interface is permitted by default.
By default logging is send to the console. You can send this to your telnet session with the term mon command.
Merry Christmas!
I have the following access-lists
access-list 101 permit udp 172.17.0.0 0.0.255.255 any eq domain
access-list 101 permit udp 172.17.0.0 0.0.255.255 any eq ntp
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq domain
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq ftp-data
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq telnet
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq smtp
access-list 101 permit tcp 172.17.0.0 0.0.255.255 any eq www
access-list 101 permit ip any host 172.17.0.16
access-list 103 permit udp host 77.246.60.90 any eq domain
access-list 103 permit udp host 77.246.60.90 any eq ntp
access-list 103 permit tcp host 77.246.60.90 any eq domain
access-list 103 permit tcp host 77.246.60.90 any eq ftp-data
access-list 103 permit tcp host 77.246.60.90 any eq 22
access-list 103 permit tcp host 77.246.60.90 any eq telnet
access-list 103 permit tcp host 77.246.60.90 any eq smtp
access-list 103 permit tcp host 77.246.60.90 any eq www
access-list 103 permit tcp host 77.246.60.90 any eq 143
access-list 103 permit tcp host 77.246.60.90 any eq 443
access-list 103 permit tcp host 77.246.60.90 any eq 465
access-list 103 permit tcp host 77.246.60.90 any eq 587
access-list 103 permit tcp host 77.246.60.90 any eq 993
access-list 103 permit tcp host 77.246.60.90 any eq 995
access-list 103 permit tcp host 77.246.60.90 any eq 8080
access-list 103 permit icmp host 77.246.60.90 any
access-list 103 permit ip host 65.88.254.131 any
Access-list 101 I am applying to fa0/0 as the in
int fa0/0
access-list 102 is only there for NAT
If I apply access-list 103 to any of the interface on the in or out the internet goes down.
If I put the previous command access-list 103 permit ip any any established it does not work. Without access-list 103 I can broswe internet but cannot connect to my mail server on port 25 or 443.
thanks for your help so far
I assume that you are applying access-list 103 on fa0/1.I would suggest that you make the following change in the access-list and then apply:
int fa0/1
ip access-group 103 in
I presume 77.246.60.90 is your interface IP address. Than this access-list is incorrect. You are permitting packets incoming on the outside interface with as source address your own IP address. you should switch source and destination.  For example access-list 103 permit udp any host 77.246.60.90 eq domain
But there is another problem. On f0/0 you only allow packets with as source your internal network and destination any but only some specified ports.
If someone access your mailserver they can have any source port and therefore the returning traffic from your mailserver can have any destination port which will be blocked.
You can solve this by adding access-list 101 permit tcp any any established
For testing you could add this command and don't place access-list 103 on the interface.
But I think if your router support this it is an better idea to use the zone-based firewall because it is statefull.
