NAT and Route map configuration
aparada14
I have a trouble trying to get connectivity using Nat and route-map together in a multihoming scenario.
5 Replies 5
aparada14
I?m seing matches in my access-list but the translation is not made. Anybody have a clue???
Here is an example of one I recently used. If you post your configuration we might see any possible errors.
ip nat pool Pool1 11.11.12.12 11.11.12.12 prefix-length 28
ip nat pool Pool2 10.10.11.11 10.10.11.11 prefix-length 28
ip nat inside source route-map MAP-1 pool Pool1 overload
ip nat inside source route-map MAP-2 pool Pool2 overload
INTERFACE VLAN2
ip nat inside
INTERFACE VLAN3
ip nat inside
interface fa0/1
ip nat outside
interface fa0/0
ip nat outside
access-list 108 deny ip 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 108 permit ip 192.168.2.0 0.0.0.255 ANY
access-list 118 deny ip 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 118 permit ip 192.168.1.0 0.0.0.255 ANY
route-map MAP-1 permit 10
match ip address 108
set default interface fa0/1
route-map MAP-2 permit 10
match ip address 118
set default interface fa0/0
Dear Sir
Can u tell the secenario and the configuration u had done
The customer has 2 T-1's going to 2 ISP's. They wanted the traffic from the 192.168.1.0/24 network to go out of the Fast0/0 interface to ISP1 and the traffic from the 192.168.2.0 network to use the Fast0/1 interface using ISP2. The traffic had to be NAT'd prior to exiting the Fast Ethernet interfaces. So this configuration did just that for them.
Can I have multiple global addresses for an internal IP in order to connect to diferent parnert network??. I mean something like:
10.0.44.50 --> 172.20.10.61 for ISP1
10.0.44.50 --> 172.20.10.64 for ISP2 and each statement associated to static nat inside source with different route-maps and access-list and have connection without problem to connect both ISPs simultaneusly
