NAT Configuration Scenario
mtevans
I need to perform a NAT function on only DNS queries destined for external DNS servers that I receive on a single physical interface - all other traffic is to remain unchanged.
These DNS queries need to be redirected to DNS servers internal to my enterprise rather than DNS servers that my wireless service provider is "telling" the client machines to use.
I "Think" all I have to add to the config is the following:
ip nat inside source x.x.2.77 y.y.2.135
ip nat inside source x.x.5.3 y.y.130.135
int fa6/7
desription Interface receiving DNS queries from clients configed with external DNS server entries.
ip nat outside
int vlan 2
desription Interface 1 connected to subnet with enterprise DNS server.
ip nat inside
int vlan 5
description Interface 2 connected to subnet with enterprise DNS server
ip nat inside
I only want NAT performed on DNS queries RX'd on int fa 6/7 destined for either y.y.2.135 or y.y.130.135. All DNS queries destined for x.x.2.77 and x.x.5.3 need to remain untouched.
Will this work ?
Is it the best way or is there an alternative ?
owaisberg
mtevans,
Why you don't want to configure your
clients which are behind interface fa6/7
with DNS address of those enterprise DNS
server. This way you need no redirection
to be performed ?
Thx,
OW
The interface is connected to a "Secure Wireless Network" (1xRTT and EVDO) that services a whole bunch of customers (Fire/Police/Ambulance/Governement, etc. The service provider is unable to specify/configure per customer DNS entries on the wireless modems other than their own servers or nothing at all. Hence the need to NAT requests coming in from these devices to our own DNS servers.
We try and stay as far away as possible from statically configuring per client any settings.
Got it now. So if DNS request coming from
NAT outside interface, to build translation that you need use following syntax:
ip nat inside source static tcp 53 53
ip nat inside source static udp 53 53
HTH,
OW
