Nat destination with rotary pool not work in Cisco ISR 4331
madmongoose
Hello!
We have finally replaced the old Cisco 2851 on the more recent Cisco 4331. The config from the old 2851 was successful moved to 4331 except for one moment. Rotary nat was used to load balance external connections to internal mail servers on 2851, but it didn't work on the new 4331.
Ambiguous command: "ip nat inside destination list 100 pool pool-mail"
This is nat related config from Cisco 2851:
ip nat pool pool-mail 10.10.10.11 10.10.10.12 netmask 255.255.255.0 type rotary
ip nat inside source list acl-nat interface GigabitEthernet0/0 overload
ip nat inside destination list 100 pool-mail
access-list 100 permit tcp any host 100.100.100.100 eq www
access-list 100 permit tcp any host 100.100.100.100 eq 443
access-list 100 permit tcp any host 100.100.100.100 eq smtp
This from Cisco 4331:
ip nat inside source list acl-nat interface GigabitEthernet0/0/0 overload
ip access-list extended 100
When I try setup nat destination, I see this "Ambiguous command: "ip nat inside destination list 100 pool pool-mail"
I read docs
But example did't work:
ip nat pool real-hosts 192.168.15.2 192.168.15.15 prefix-length 28 type rotary
access-list 2 permit 192.168.15.1
ip nat inside destination list 2 pool real-hosts
interface gigabitethernet 0/0/0
ip address 192.168.15.129 255.255.255.240
ip nat inside
interface serial 0
ip address 192.168.15.17 255.255.255.240
ip nat outside
rt-01(config)#$s 192.168.15.2 192.168.15.15 prefix-length 28 type rotary
rt-01(config)#access-list 2 permit 192.168.15.1
rt-01(config)#ip nat inside destination list 2 pool real-hosts
% Ambiguous command: "ip nat inside destination list 2 pool real-hosts"
I have Cisco ISR 4331 HSECK9 Version 16.9.7 Fuji
Community, please help.
Good day!
Unfortunately it didn't help...(
But I solved the problem in a completely random way and it worked!
I added the ip address 10.131.2.10, which is not in my subnet and made a forwarding to it from external ip.
This is worked config:
x- external ips, w - another PAT
ip nat pool ais-pool-mail 10.131.1.11 10.131.1.12 prefix-length 29 type rotary
ip nat inside source static tcp 10.131.2.10 25 x.x.x.x 25 extendable
ip nat inside source static tcp 10.131.2.10 80 x.x.x.x 80 extendable
ip nat inside source static tcp 10.131.2.10 443 x.x.x.x 443 extendable
ip nat inside source static tcp 10.131.2.10 465 x.x.x.x 465 extendable
ip nat inside source static tcp 10.131.2.10 587 x.x.x.x 587 extendable
wwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwwww
ip nat inside source list ais-nat interface GigabitEthernet0/0/0 overload
ip nat inside destination list ais-acl-mail pool ais-pool-mail
ip route 0.0.0.0 0.0.0.0 x.x.x.x
ip route 10.131.1.0 255.255.255.0 GigabitEthernet0/0/1
ip ssh version 2
ip access-list standard ais-nat
10 permit 10.131.1.0 0.0.0.255
ip access-list extended ais-acl-mail
10 permit tcp any host x.x.x.x eq www
20 permit tcp any host x.x.x.x eq 443
30 permit tcp any host x.x.x.x eq smtp
40 permit tcp any host x.x.x.x eq 465
50 permit tcp any host x.x.x.x eq 587
Thanks everyone for the help!
16 Replies 16
kubn2
Based on the output that you've pasted you are using the command:
However in the documentation the command looks like this:
ip nat inside destination-list 2 pool real-hosts
So try with "destination-list" instead of "destination list"
Screen Shot 2021-04-05 at 00.35.06.pngThank you for answer. This is example from Cisco Configuring NAT for isr 4300 Fuji firmware. My config above. But I try this...
Enter configuration commands, one per line. End with CNTL/Z.
rt-01(config)# ip nat pool real-hosts 192.168.15.2 192.168.15.15 prefix-length 28 type rotary
rt-01(config)#ip nat inside destination-list 2 pool real-hosts
% Invalid input detected at '^' marker.
rt-01(config)#ip nat inside destination list 2 ?
redundancy NAT redundancy operation
<cr> <cr>
try this post :
https://community.cisco.com/t5/routing/forward-range-ports-for-few-hosts-in-isr4331/td-p/3316899
still an issue please post-show version
BB
Thank you for answer!
Yes, named ACL passed.
Is the work config:
ip nat pool ais-pool-mail 10.131.1.11 10.131.1.12 netmask 255.255.255.0 type rotary
  permit tcp any any eq www
  permit tcp any any eq 443
  permit tcp any any eq smtp
  permit tcp any any eq 465
And then an amazing poltergeist begins. The telnet test passes from external devices on Windows, http page opens, but it does not work from macos, iphone, linux devices.
From linux and macOS:
telnet x.x.x.x 465
telnet: Unable to connect to remote host: Connection refused
telnet: can't connect to remote host (x.x.x.x Connection refused
From Windows:
220 mail-01.xxx.ru Microsoft ESMTP MAIL Service ready at Mon, 5 Apr 2021 12:28:10 +0300
quit
220 mail-02.xxx.ru Microsoft ESMTP MAIL Service ready at Mon, 5 Apr 2021 12:28:52 +0300
Load balancing is worked, but not for all.
rt-01#sh ver
Cisco IOS XE Software, Version 16.09.07
Cisco IOS Software [Fuji], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.7, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Wed 10-Feb-21 09:23 by mcpre
ROM: IOS-XE ROMMON
ais-rt-01 uptime is 16 hours, 45 minutes
Uptime for this control processor is 16 hours, 47 minutes
System returned to ROM by Reload Command at 19:43:53 MSK Sun Apr 4 2021
System restarted at 19:48:39 MSK Sun Apr 4 2021
System image file is "bootflash:isr4300-universalk9.16.09.07.SPA.bin"
Last reload reason: Reload Command
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 appxk9 RightToUse appxk9
uck9 None None None
securityk9 securityk9 RightToUse securityk9
ipbase ipbasek9 Permanent ipbasek9
The current throughput level is 100000 kbps
Smart Licensing Status: Smart Licensing is DISABLED
cisco ISR4331/K9 (1RU) processor with 1784185K/6147K bytes of memory.
Processor board ID FDO2219A08H
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
0K bytes of WebUI ODM Files at webui:.
Configuration register is 0x102
Firmware upgrade to last version. It all looks like a bug.
Thank you for answer. I've written so much, but I don't see it here. I'll start again.
Named ACL is accept!
x.x.x.x - external ip
Now my config looks like this. And it worked! But not for everyone. This is some incredible poltergest. And it looks like a bug. Load balancing only works for external Windows clients. I can open the http page, connect telnet on port 465. But when I try to do the same with macos, iphone or linux the connection is refused.
On Windows clients:
220 xxx-01.xxx Microsoft ESMTP MAIL Service ready at Mon, 5 Apr 2021 12:28:10 +0300
220 xxx-02.xxx Microsoft ESMTP MAIL Service ready at Mon, 5 Apr 2021 12:28:52 +0300
I try connect from other City - worked!
On *nix clients:
telnet x.x.x.x 465
telnet x.x.x.x 465
Trying x.x.x.x...
I have no idea how to diagnose it...
#sh ver
ROM: IOS-XE ROMMON
ais-rt-01 uptime is 18 hours, 13 minutes
Uptime for this control processor is 18 hours, 15 minutes
securityk9
appxk9
uck9
cme-srst
cube
uck9 None None None
Thanks for your help and your time.
Hello
It seems you are not running the correct software or license to support the load balancing, have you tried upgrading the router?
Also regards your configuration  you are currently including the broadcast address for the subnet in the nat pool..
it should be
192.168.15.2 192.168.15.14
Kind Regards
Paul
@paul - Good catch..
BB
Please note this is taken from the official Cisco documentation. And there are claims to their writer. But no matter, my config is a different, I wrote about it above. In my config with addresses and mask everything is in order.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/xe-16-8/nat-xe-16-8-book/iadnat-addr-consv.html?bookSearch=true
ip nat pool ais-pool-mail 10.10.10.11 10.10.10.12 netmask 255.255.255.0 type rotary
Hello
Does your rtr except the pool the above suggests otherwise?
Also the access-list relatng to the public ip address for the serverpool, Is this separate from your public wan interface ip address address?
Kind Regards
Paul
I didn't quite understand the question.
Yes, pool only for two mail servers. ACL for mail different from nat acl.
You are asking questions following an example taken from the documentation, which, as we found out, is not written correctly. And it no longer makes sense to disassemble it.
I would be grateful if you can figure out the main config. As I wrote above, balancing worked for Windows clients, but does not work for iphone, mac, linux. This is my actual config.
On Windows clients:
On *nix clients:
telnet x.x.x.x 465
telnet x.x.x.x 465
Trying x.x.x.x...
#sh ver
ROM: IOS-XE ROMMON
Hello
Okay I think we got lost somewhere but now i believe we are on the same lines.
Now regards your nat configuration, I see two acls for nat, one performing PAT for the whole lan and one for NAT load balancing.
As a test can you deny the hosts that are being stated in acl ais-nat-mail from acl ais-nat making sure the deny ace's are above the permit aces statement
Example:
ip access-list extended ais-nat
1 deny tcp host x.x.x.x any
2 deny tcp host x.x.x.y any
etc
Kind Regards
Paul
Good day!
My config with the ais-nat  acl look like this:
ip nat inside source static tcp 10.131.1.40 x.x.x.x extendable
ip nat inside source static udp 10.131.1.40 x.x.x.x extendable
20 permit 10.131.3.0 0.0.0.255
30 permit 192.168.7.0 0.0.0.255
40 permit 10.131.10.0 0.0.0.255
I didn't understand a bit why I need to make a deny rule?
Don't you find it interesting that Windows clients work in this configuration, but Linux, MacOS, iPhone, Android does not?
By the way, only telnet 587 passes for Unix.
Yesterday I updated the firmware to the latest possible Bengaluru 17.04.01b. I deleted all the config associated with NAT, made the settings again, but nothing changed.
Thank you for help!
Hello
It does seem strange ,Are those other devcies accessing the internal server the way as the window machines?
As for the ammendment, What i mean is deny the hosts that are being stated in the ais-acl-mail acl in the ais-nat acl:
4 deny host x.x.x.w
5 deny host x.x.x.x
6 deny host x.x.x.y
7 deny host x.x.x.z
Kind Regards
Paul
Good day!
ip ssh version 2
