NAT Fails
hadisharifi
Hi, I am trying to NAT inside hosts to access the internet but it fails and gives this error message. Can somone please help what is going on.
(NAT*: Can't create new inside entry - forced_punt_flags: 0)
interface Dialer1
ip address X.X.X.X 255.255.255.0
ip nat outside
ip virtual-reassembly
encapsulation ppp
dialer pool 1
no cdp enable
ppp authentication chap callin
ppp chap hostname XX@XX
ppp chap password 0 XX
interface Vlan2
ip address 192.168.7.1 255.255.255.0
ip nat inside
5 Replies 5
Nagaraja Thanthry
Can you please post all the NAT configurations here?
NT
Hi, that is all the NAT configuration.
If that is the case, can you please try the following:
Hi, Thanks I have resolved it. It does help when people don't login and remove the config you put in
I am glad that the issue is fixed. Please mark the thread as answered.
NT
