NAT for Dual WAN Interfaces Using ACLs
austin.lechelt
I have two questions regarding this subject; first, why doesn’t it work when referencing ACL’s in two different NAT statements on a Cisco ISR router?
!---Routing and interface configurations omitted---
ip nat inside source list NAT_172.16 interface Dialer0 overload
ip nat inside source list NAT_Alt_172 interface GigabitEthernet0 overload
ip access-list standard NAT_172.16
 remark NAT 430 Traffic to Internet
 permit 172.16.0.0 0.0.255.255
 deny   any
ip access-list standard NAT_Alt_172
 remark NAT 430 Traffic to Alt Internet
 deny   any
Second, how do the route-maps work without a “set” statement?
access-list 100 permit ip 172.168.60.0 0.0.0.255 any
route-map isp1 permit 10
match ip address 100
match interface FastEthernet0/0
route-map isp2 permit 10
match interface FastEthernet1/0
ip nat inside source route-map isp1 interface FastEthernet0/0 overload
ip nat inside source route-map isp2 interface FastEthernet1/0 overload
Just trying to wrap my head around this.
Philip D'Ath
In both cases, only "match" criteria are considered.
In the below case, the only match being specified is an access-list, and both access-lists are the same.  So this wont work at all well.
In the next case, the route-map is saying both an access-list and the outbound interface must match - which will be unique.
No "set" is required because you are already matching the outbound interface - it is already going out the interface required.
Philip D'Ath
Thank you! I have one additional question; I tried the route-map:
...and it works!
From my understanding the statement:
Is worded like this:
NAT inside to outside source (Fa0/0) destination: (Fa0/0)
How then is the following to be true:
NAT inside to outside source Fa0 to Fa0...where is the source specified? I see where the destination is specified (in the NAT statement: Fa0/0)...but the source matches the destination???
