NAT inside destination not working
saba
My setup is on gns3, dynamips.
What I'm trying to do is a load balancing between two identical servers using NAT.NAT inside destination.png
The server addresses are 192.168.48.74 and .75. With one public address, I'd like my clients on the internet to access those servers. So if my clients on the internet try to connect to the server through the public address, the router R1 should translate it to one of the local addresses.
This should be done with 'ip nat inside destination list' command according to some articles[1]. But in my setting it doesn't work at all. Can anyone help me?
R1 configuration is as follows:
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback0
 ip address 10.10.11.1 255.255.255.248
interface Loopback1
 ip address 192.168.48.1 255.255.255.224
 ip ospf network point-to-point
interface Loopback2
 ip address 192.168.48.33 255.255.255.224
interface Loopback3
 ip address 192.168.64.1 255.255.255.224
interface Loopback4
 ip address 192.168.64.33 255.255.255.224
interface Loopback5
 ip address 192.168.80.97 255.255.255.224
interface Loopback6
 ip address 192.168.80.193 255.255.255.224
interface Serial0/0
 no ip address
 encapsulation frame-relay
 serial restart-delay 0
 no frame-relay inverse-arp
 frame-relay lmi-type ansi
interface Serial0/0.13 multipoint
 ip address 200.200.17.5 255.255.255.252
 frame-relay map ip 200.200.17.6 103 broadcast
interface Serial0/1
 ip address 200.200.17.13 255.255.255.252
interface Serial0/2
 no ip address
interface Serial0/3
 no ip address
 shutdown
interface Ethernet1/0
 ip address 200.200.17.18 255.255.255.252
 ip nat outside
 ip virtual-reassembly
 full-duplex
interface Ethernet1/1
 no ip address
 full-duplex
interface Ethernet1/1.15
 encapsulation dot1Q 600
 ip address 166.15.13.1 255.255.255.252
interface Ethernet1/1.17
 encapsulation dot1Q 107
 ip address 192.168.32.1 255.255.255.240
 ip nat inside
interface Ethernet1/1.18
 encapsulation dot1Q 108
 ip address 192.168.32.17 255.255.255.240
 ip nat inside
interface Ethernet1/2
 no ip address
 shutdown
 half-duplex
interface Ethernet1/3
 no ip address
 shutdown
 half-duplex
router ospf 1
 router-id 10.10.11.1
 log-adjacency-changes
 area 0 authentication message-digest
 area 192 virtual-link 10.10.13.3 message-digest-key 53 md5 sj79aqj2dn0js
 passive-interface default
 no passive-interface Serial0/0.13
 no passive-interface Serial0/1
 no passive-interface Ethernet1/1.17
 no passive-interface Ethernet1/1.18
 network 192.168.32.1 0.0.0.0 area 1003
 network 192.168.32.17 0.0.0.0 area 1003
 network 192.168.48.0 0.0.0.63 area 1003
 network 192.168.64.0 0.0.0.63 area 1003
 network 192.168.80.96 0.0.0.31 area 1003
 network 192.168.80.192 0.0.0.31 area 1003
 network 200.200.17.5 0.0.0.0 area 192
 network 200.200.17.13 0.0.0.0 area 192
 default-information originate always
ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 200.200.17.17
ip nat pool RETAIL-WEB-LOCAL 192.168.48.74 192.168.48.75 prefix-length 29 type rotary
ip nat inside source list NAT-GRP interface Ethernet1/0 overload
ip nat inside destination list RETAIL-WEB-GLOBAL pool RETAIL-WEB-LOCAL
ip access-list standard NAT-GRP
 permit 192.168.48.0 0.0.0.63
 permit 192.168.64.0 0.0.16.255
ip access-list standard RETAIL-WEB-GLOBAL
 permit 200.200.17.34
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
SW3 config is as follows:
hostname SW3
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
ip cef
no ip domain lookup
interface Loopback1
 ip address 192.168.48.65 255.255.255.248
interface Loopback2
 ip address 192.168.48.73 255.255.255.248
interface Loopback3
 ip address 192.168.48.81 255.255.255.248
interface Loopback4
 ip address 192.168.80.1 255.255.255.224
interface Loopback5
 ip address 192.168.80.33 255.255.255.224
interface Loopback6
 ip address 192.168.48.137 255.255.255.248
interface Port-channel1
 switchport mode trunk
interface Port-channel2
interface Port-channel3
interface FastEthernet1/0
 switchport access vlan 210
interface FastEthernet1/9
 channel-group 2 mode on
interface FastEthernet1/10
interface FastEthernet1/11
 channel-group 3 mode on
interface FastEthernet1/12
interface FastEthernet1/13
 channel-group 1 mode on
interface FastEthernet1/14
interface FastEthernet1/15
interface Vlan1
 no ip address
interface Vlan108
 ip address 192.168.32.18 255.255.255.240
 ip access-group CTRL-RETAIL-TELLER in
interface Vlan708
 ip address 192.168.32.34 255.255.255.240
router ospf 1
 router-id 10.10.11.3
 no passive-interface Vlan108
 no passive-interface Vlan708
 network 192.168.32.18 0.0.0.0 area 1003
 network 192.168.32.34 0.0.0.0 area 1003
 network 192.168.48.64 0.0.0.31 area 1003
 network 192.168.80.0 0.0.0.7 area 1003
 network 192.168.80.32 0.0.0.7 area 1003
ip http server
ip access-list extended CTRL-RETAIL-TELLER
 permit ip 192.168.48.0 0.0.0.15 192.168.48.68 0.0.0.1
 permit ip 192.168.48.32 0.0.0.7 192.168.48.68 0.0.0.1
 deny   ip any 192.168.48.64 0.0.0.7
 permit ip any any
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line vty 0 4
 login
end
ip nat statistics on R1 shows the following:
R1#sh ip nat stat
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Outside interfaces:
  Ethernet1/0
Inside interfaces:
  Ethernet1/1.17, Ethernet1/1.18
Hits: 0  Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 1] access-list NAT-GRP interface Ethernet1/0 refcount 0
-- Inside Destination
[Id: 2] access-list RETAIL-WEB-GLOBAL pool RETAIL-WEB-LOCAL refcount 0
 pool RETAIL-WEB-LOCAL: netmask 255.255.255.248
        start 192.168.48.74 end 192.168.48.75
        type rotary, total addresses 2, allocated 0 (0%), misses 0
Queued Packets: 0
When I tried to ping 200.200.17.34 from ISP, it fails. It doesn't even create any "ip nat translation" entry. It tries to route the address without going through nat at all.
6 Replies 6
where is 200.200.17.34 configured ? I don't see an ip nat outside interface in your configuration with that IP address...
I didn't think that address has to be assigned in an interface. That
address needs to be translated, and the article explaining ip nat inside
destination doesn't have any interface assigned with the public address
which needs to be translated.
Do you think I should change the public address to the address associated
in the ip nat interface?
you are right, my bad, the interface address does not have to match the public address.
Looking through your config, check your inside NAT access list, it doesn't include the addresses for your servers:
permit 192.168.48.0 0.0.0.63 --> includes only hosts 1 - 62, change the wildcard to 0.0.0.127
Also, can you ping 192.168.48.74 from the router ? I cannot fully figure out what your network looks like, since you have a virtual llink (to where ?) and your switch, is supposed to be a layer 3 switch ?
Hello
You need to be able to have 200.200.17.34 available for you to use and advertised by you isp, your global inside addressing 200.200.17.18/30 doesn't even extend to this ip address so why are you trying to connect via it?
As for your destination nat config this looks okay
res
Paul
Kind Regards
Paul
I do have the address 200.200.17.34 though it's not in any of the loopback interfaces. ISP has that in static routes. I didn't set up the loopback because they don't have any routing protocols between R1 & ISP.
you have a virtual link with area 192 being the transit area. What re you linking to ?
Try and take the access list 'ip access-list standard NAT-GRP' out of your configuration altogether...
no ip access-list standard NAT-GRP
