NAT/inspect issue
Robert Craig
Level 3
Level 3
I have been trying to figure out a NAT issue on my 2811 and the inspect engine.
I have 'ip inspect FW out' on my outside interface. If I turn it off, I also have to remove the access-list applying to inbound traffic on that same interface. Why is that? This whole thing centered around SIP registrations from devices on my LAN to my provider. The provieder is showing that I am registering from a high end port (1024 or something crazy). He said that it sounds like some type of SIP ALG or something on my router. For the life of me, I can't figure out what would be causing it. I am just using a standard route-map that points to the outside interface using 'overload'. Am I missing something?
6 Replies 6
cadet alain
What's the need of inspecting traffic to permit return traffic is there is no ACL blocking WAN traffic inbound?
If you've got no  ACL filtering traffic inbound then you don't need to inspect anything as all returning traffic will be permitted.
If you want to disable ALG for SIP you should try this:
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
Regards.
Alain
Robert Craig
Level 3
Level 3
Ok. So why is there a requirement for inspection when an ACL is applied inbound? Also, is the SIP ALG on by default?
hi,
the inspection is needed to create a state table and permit the return traffic for outbound traffic that is in this state table so
no taking into account the inbound ACL denying this traffic.
yes afaik the SIP ALG is the default.
Regards.
Alain
Robert Craig
Level 3
Level 3
Ok, we'll thank you very much for the help. I appreciate it.
paolo bevilacqua
"ip inspect" has nothing to with NAT. It enables some sort of IOS firewall.It is not needed or helpfult at all, and can be removed altogether.
Robert Craig
Level 3
Level 3
Well, I would remove it, but when I do, traffic fails unless I remove the ACL inbound on the WAN interface, which I don't want to do.
