Software to detect my Network topolgy?
Manuel Nin
Hi! I want to know if someone know the name of a Software that detect and draw automatically my interconnected network.
I run the software in my pc, and the software draw for me how my network is actually connected.
Thanks!
_
Manuel.
david.tran
Level 4
Level 4
try a product from OpNet call VNE/network mapper.  It will do exactly what you described.  I can't speak on the accuracy of this product
You just have to make your own judgment on this product.  I've used it and my opinion is biased and you really don't want to know what I think about it.
Hi Mr David,
I am very interested to know your opinion about the Opnet NETmapper if it'is better than NetBrain?
thx a lot
Collin Clark
Here's a couple-
Solarwinds
http://www.solarwinds.com/products/lansurveyor/info.aspx
NetBrain
http://www.netbraintech.com/network-diagram/
IMO the NetBrain product is miles ahead of Solarwinds in discovering a network. It's what I use when I go into a new client and need to find out their topoology.
Hope it helps.
nspasov
I would have to agree with Collin. NetBrain is pretty slick when it comes to network discovery and document creation.
