NAT IP translation
ahpark78
If I already have ip nat static inside source configuration on the interface S0,how can I do a IP Nat static inside for diff IP NAT translation on another interface??
Thanks in advanced.
ken L
11 Replies 11
mahmoodmkl
Level 7
Level 7
HI
Can u more briefly describe u r problem as it not clear.
Mahmood
Hi Mahmood,
Something like I have this internal IP:
192.168.1.1
need to NAT to 203.10.5.1
and have another internal IP: 192.168.1.2
need to NAT to 203.10.5.2
The reason why is both are diff servers and have diff WAN external connection to come in to access..So I need to have diff IPs NATed to diff internal IPs.
thks Mahmood..
ken L
HI
192.168.1.1
this is correct.
u can nat it also.
but i didnt get u r third point i.e u have different wan external connection do u mean that u have different service providers ..?
Mahmood
Sorry Mahmood,
I am confusing you, you can ignore the third point.
My problem is what you have stated .
Internal IP 192.168.1.2 NATe to 203.10.5.2
Internal IP 192.168.1.1 NATed to 203.10.5.1
and this must be done on same router..
thanks again!
ken L
HI
u can go like this
ip nat inside source static 192.168.1.2 203.10.5.2
ip nat inside source static 192.168.1.1 203.10.5.1
ofcourse u can configure it.
mahmood
Hi Mahmood,
How to differiate the "ip nat inside" that correspondence in between interfaces..??
eg:
if i hvave 2 interfaces:
int s0/0
which this interface takes the ip nat inside source static 192.168.1.2 203.10.5.2
and
int s0/1
which this interface takes seconde one
Example is,
How int s0/0 or S0/1 know which IP to take to NAT as both
also configured as "IP NAT inside"?
HI
For successful NAT scenario u must have one interface as NAT INSIDE and one as NAT OUTSIDE without this i think it is not possible.
Mahmood
Mahmood,
I think you are getting me there already..
Can I know what is the diff between NAT INSIDE AND NAT OUTSIDE??
Any good article read-up for this before my implementation??
thks!
rgds
kenny
HI
I hope this link will help u.
http://www.cisco.com/warp/public/556/5.html
Mahmood
Thanks Mahmood! :D
I will rate this post as you have solved my problem.
Indeed can use both together..as below..
Thanks again! :D
