NAT Issue?
js358
Hello All:
Have an issue and am not quite sure of the cause.
Segmented network, 1.x, 2.x, 3.x
Have a 2600 Router servicing the 3x clients for internet connectivity.
FA0/0 ip address 10.0.3.1
IP NAT inside
This interface used as gateway for 3.x clients to route out 3 T1's
Route statement for all 3 serials
ip route 0.0.0.0 0.0.0.0 ser0/0, 0/1, 0/2
ip nat ouside on all 3.
The problem. I have a webserver sitting on 2.x network. I have a static map on the router from external ip to 10.0.2.20.
Now, the problem is intermittant but this website mapped through this router chokes sometimes...can't ping it from the outside and it won't serve any pages. All other IP's on this router are fine and accessible from outside. All internal routing is fine.
The kicker...I dual honed the web server and gave it a 3.x address on the second NIC. I natted an ip to it and it is rock solid, no problems at all, even when the webserver cannot serve up pages for the site on the 2.x segment.
Any idea as to why this is happening??
Thanks.
5 Replies 5
johansens
Level 4
Level 4
Where/how is your 1.x and 2.x networks connected?
ethernet ports on common router
It is better to have a full global link upto your webserver. You assign a global address as primary on the webserver and if required for internal use (intranet) assign a secondary address also. Do the same thing at the ruter's ethernet interface with global primary & local secondary at the webserver configure Global address on the router as gateway.
Krishnamurthy Suresh
alfredshum
If you're running NAT with multiple NAT pools or interfaces, you need to use route-map and in your case should be something like this:
route-map port0 permit 10
match interface s0/0
route-map port0 permit 1000
route-map port1 permit 10
match interface s0/1
route-map port1 permit 1000
route-map port2 permit 10
match ip address list 10
match interface s0/2
route-map port2 permit 1000
access-list 10 permit host a.b.c.d
ip nat inside source route-map port0 interface s0/0
ip nat inside source route-map port1 interface s0/1 overload
ip nat inside source route-map port2 e.f.g.h
Of course you can use more "match" state to refine your match, say "match ip address" for specific servers. Also you can replace the interface on that NAT statement with an outside IP address or a pool of addresses. Very flexible.
For a better understanding of the NAT-Routemaps, follow this link.
http://www.ciscotaccc.com/iprout/showcase?case=K39240839
Note:Rate it!
MAR
