NAT not applying to VRF's
Glenn Matthys
I'm experimenting with VRF's, I'm trying to do NAT from one VRF to another, using a loopback interface.
I have one internet VRF (BLUE) and one "local" VRF (RED), and translation has to happen in the RED VRF. I've created a loopback interface which has the "special" IP address, 192.168.2.100. I'm trying to get all packets from Vlan1 with source 192.168.1.0/24 to be source translated to loopback0's IP, 192.168.2.100, so packets coming in on Vlan1 should leave out of fa0 with IP address 192.168.2.100. Right now, that's not happening... packets leave fa0 but with their original source address.
So I got the inter-VRF routing to work using BGP, but the NAT rule doesn't do anything... That's where I'm stuck. Here's my configuration:
! Last configuration change at 15:48:41 UTC Sun Dec 30 2012 by admin
version 15.1
hostname r3
boot-start-marker
boot-end-marker
vrf definition BLUE
rd 65000:2
route-target export 65000:2
route-target import 65000:1
address-family ipv4
exit-address-family
vrf definition RED
rd 65000:1
route-target export 65000:1
route-target import 65000:2
address-family ipv4
exit-address-family
logging buffered 16384
no aaa new-model
dot11 syslog
no ip source-route
ip cef
ip domain name ciscolab
no ipv6 cef
license udi pid CISCO1811/K9 sn xxx
vtp mode transparent
username admin privilege 15 password 0 admin
ip ssh version 2
ip ssh pubkey-chain
username admin
key-hash ssh-rsa xxx
quit
bridge irb
interface Loopback0
vrf forwarding RED
ip address 192.168.2.100 255.255.255.255
ip nat outside
ip nat enable
ip virtual-reassembly in
interface FastEthernet0
vrf forwarding BLUE
ip address 192.168.0.5 255.255.255.0
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface FastEthernet4
no ip address
interface FastEthernet5
no ip address
interface FastEthernet6
no ip address
interface FastEthernet7
no ip address
interface FastEthernet8
no ip address
interface FastEthernet9
no ip address
interface Vlan1
vrf forwarding RED
ip address 192.168.1.254 255.255.255.0
ip nat inside
ip nat enable
router bgp 65000
bgp log-neighbor-changes
address-family ipv4 vrf BLUE
redistribute connected
exit-address-family
address-family ipv4 vrf RED
exit-address-family
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat source list NAT interface Loopback0 vrf RED overload
ip access-list extended NAT
permit ip 192.168.1.0 0.0.0.255 any
dialer-list 1 protocol ip permit
route-map test permit 10
control-plane
line con 0
speed 115200
line 1
modem InOut
stopbits 1
speed 115200
flowcontrol hardware
line aux 0
line vty 0 4
login local
transport input all
end
Wouter Prins
Wouter Prins
Solved on IRC
With the help from above, looks like I messed up my NAT configuration but just not saw it. For completeness, the entire working configuration:
Current configuration : 2532 bytes
! Last configuration change at 21:48:59 UTC Sun Dec 30 2012 by admin
version 15.1
hostname r3
boot-start-marker
boot-end-marker
vrf definition BLUE
rd 65000:2
address-family ipv4
exit-address-family
vrf definition RED
rd 65000:1
address-family ipv4
exit-address-family
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ipv6 cef
license udi pid CISCO1811/K9 sn xxxx
username admin privilege 15 password 0 xxxx
ip ssh version 2
ip ssh pubkey-chain
username admin
key-hash ssh-rsa xxxx
quit
bridge irb
interface Loopback0
vrf forwarding RED
ip nat outside
vrf forwarding BLUE
ip nat outside
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
interface Vlan1
vrf forwarding RED
ip nat inside
interface Async1
no ip address
encapsulation slip
router bgp 65000
exit-address-family
exit-address-family
no ip http server
ip nat inside source list NAT interface Loopback0 vrf RED overload
control-plane
line con 0
speed 115200
line 1
modem InOut
stopbits 1
speed 115200
line aux 0
line vty 0 4
login local
transport input all
end
