NAT overload using nat pools
q-coelho
I am hoping someone else has had the same problems or a possible resolution.
I have 2 GRE tunnels terminating on ISP router, their IP ranges routed to the tunnels are Private IP's. I want to translate one of the class C blocks to one public IP and the other class C block to another public IP. But when traffic is destined for my internal network, it should not be required to be translated.
My configurations are as below:
interface Loopback10
description test2
ip address 192.168.1.1 255.255.255.255
interface Loopback11
description test3
ip address 192.168.1.2 255.255.255.255
interface Tunnel10
description test2
ip unnumbered FastEthernet0/0
ip nat inside
tunnel source Loopback10
tunnel destination 196.x.1.1
interface Tunnel11
description test3
ip nat inside
tunnel source Loopback11
tunnel destination 196.x.2.1
interface FastEthernet0/0
description Link To Internal Network
ip address 196.x.x.x 255.255.255.224
interface FastEthernet0/1
description Link To ISP
ip address 196.x.x.x 255.255.255.254
ip nat outside
ip route 192.168.10.0 255.255.255.0 Tunnel10
ip route 192.168.11.0 255.255.255.0 Tunnel11
ip nat pool TEST2 x.x.x.40 x.x.x.40 prefix-length 32
ip nat pool TEST3 x.x.x.41 x.x.x.41 prefix-length 32
ip nat inside source route-map TEST2 pool TEST2 overload
ip nat inside source route-map TEST3 pool TEST3 overload
access-list 110 permit ip 192.168.10.0 0.0.0.255 any log
access-list 111 permit ip 192.168.11.0 0.0.0.255 any log
route-map TEST2 permit 10
match ip address 110
route-map TEST3 permit 10
match ip address 111
000359: *Mar 5 22:26:44.644 SA: NAT: map match TEST2
000360: *Mar 5 22:26:44.644 SA: NAT: address not stolen for 192.168.10.2, proto 17 port 1041
000361: *Mar 5 22:26:44.644 SA: NAT: failed to allocate address for 192.168.10.2, list/map TEST2
000362: *Mar 5 22:26:44.644 SA: NAT: translation failed (A), dropping packet s=192.168.10.2 d=209.212.97.1
000363: *Mar 5 22:26:45.424 SA: NAT: map match TEST2
000364: *Mar 5 22:26:45.424 SA: NAT: address not stolen for 192.168.10.2, proto 17 port 1041
000365: *Mar 5 22:26:45.424 SA: NAT: failed to allocate address for 192.168.10.2, list/map TEST2
000366: *Mar 5 22:26:45.424 SA: NAT: translation failed (A), dropping packet s=192.168.10.2 d=196.4.160.2
000367: *Mar 5 22:26:46.200 SA: NAT: map match TEST2
000368: *Mar 5 22:26:46.204 SA: NAT: address not stolen for 192.168.10.2, proto 17 port 1041
000369: *Mar 5 22:26:46.204 SA: NAT: failed to allocate address for 192.168.10.2, list/map TEST2
000370: *Mar 5 22:26:46.204 SA: NAT: translation failed (A), dropping packet s=192.168.10.2 d=209.212.97.1
a-vazquez
Level 6
Level 6
NAT overloading, is a feature of Cisco IOS NAT and can be used to translate internal (inside local) private addresses to one or more outside (inside global ;usually registered) IP addresses. Unique source port numbers on each translation are used to distinguish between the conversations.
With NAT overload, a translation table entry containing full address and source port information is created.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
