NAT port forward doesn't work from inside LAN.
sniperwolf3
Hi Guys,
I have a question about NAT. I have a feeling that im doing something wrong.  We have a few extra IP addresses that we have bought from our ISP. they are routed to us over our ADSL connection. what I am trying to do is port forward various ports to various servers inside our network. i have done that using the following command:
ip nat inside source static tcp 10.10.5.73 443 2XX.2XX.3X.193 443 extendable
this all works as expected when you are coming from the outside on the Internet. However when you are on the LAN (10.10.5.0/24) and try to go to https://2XX.2XX.3X.193 it doesn't work. If you ping that address (ICMP doesnt have a portforward) from the inside, the TTL just expires. if you tracert that address, once it leaves my router, it just loops between two routers untill it expires.
so my question is. how can i make it so that when I go to https://2XX.2XX.3X.193 from inside the LAN it will NAT to the correct destination?
I was thinking that I might need to put the IPs on an interface or some thing. but that also doesnt really seem right. plz help!
Here is my config:
Current configuration : 4329 bytes
version 12.4
no service pad
service password-encryption
hostname Thornton
boot-start-marker
boot-end-marker
logging message-counter syslog
enable secret 5
enable password 7
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone GMT 0
clock summer-time GMT recurring last Sun Mar 1:00 last Sun Oct 2:00
crypto pki trustpoint TP-self-signed-1150616158
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1150316158
revocation-check none
rsakeypair TP-self-signed-1150316158
crypto pki certificate chain TP-self-signed-1150616158
certificate self-signed 01
  CERTIFICATE OMITTED
        quit
dot11 syslog
ip source-route
ip cef
ip domain name jaythom.local
ip name-server 10.10.5.14
ip name-server 10.10.5.83
ip inspect log drop-pkt
no ipv6 cef
username name privilege 15 secret 5
username othername privilege 15 secret 5
archive
log config
  logging enable
  logging size 600
  hidekeys
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 8/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
switchport mode trunk
macro description cisco-switch
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface Vlan1
description $FW_INSIDE$
ip address 10.10.5.251 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
description $FW_OUTSIDE$
ip address negotiated
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname namegoeshere@L2TP.tpg.com.au
ppp chap password 7
ppp pap sent-username namegoeshere@L2TP.tpg.com.au password 7
ppp ipcp dns request
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static tcp 10.10.5.73 25 2XX.2XX.3X.193 25 extendable
ip nat inside source static tcp 10.10.5.12 443 2XX.2XX.3X.193 443 extendable
ip nat inside source static tcp 10.10.5.153 443 2XX.2XX.3X.194 443 extendable
ip nat inside source static tcp 10.10.5.94 443 2XX.2XX.3X.196 443 extendable
ip nat inside source static tcp 10.10.5.73 443 2XX.2XX.3X.197 443 extendable
access-list 1 permit 10.10.5.0 0.0.0.255
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
password 7
scheduler max-task-time 5000
end
12 Replies 12
johnlloyd_13
Level 9
Level 9
Hi Kyle,
Your config looks fine. Make sure the host 10.10.5.73 has all the right IP settings and able to ping the DG.
You could also verify from the router by doing the command:-
#telnet 10.10.5.73 443 /source-interface vl1
grinch182
Good day,
Could you please explain more clear your situation?
From which address are you trying to ping?
Which hosts works fine and which directions?
Pardon me but I can't find NAT pool in your config.
PS
If it's possible could you please attach small scheme of your netwrok for better understanding.
Sincerely,
GRinch
sniperwolf3
Thanks Guys,
grinch182 you are right, there is no NAT pool in my config.  perhaps that is my problem? I will have to add one and see if that fixes  it. in the mean time though, I have made a diagram of what im trying to  do and attached it to this post. it may look silly when you look at it. but i do have a good reason  for trying to do, what im trying to do.
That is trully interesting situation, my riend =)
You said it's routing loop somewhere and you packet dies as soon as TTL expire.
Could you plese explain me at which area it happens?
I belive your sheme doesn't contain all devices you use. Your server and router are connected directly to your router?
And main question is which goal are you trying to reach? =)
-GRinch
By the way your configuration is correct too. I just cant understand one moment, are you trying NAT few devices with single address, or in last octet you have different numbers?
Please make a comand ping from your hosts and run debug ip nat. And let us see output of debugging.
-GRinch
-GRinch
Hi Grinch,
sorry about that. yes the numbers in the last octet are different. we have 5 public IPs and we port forward different ports from these to different hosts in our network. bascaly what im trying to achieve is this:
We have a domain name on the Internet. For example https://mail.company.com.au. and that resolves to one of those public IP addresses. On the old router (non Cisco) this was all well and good. we just set the portforward and from inside the network you could go to that address and it would still resolve and be NATed and work as you would expect it too. What is happening now is, when i go to that address from inside the netwrok, it just doesn't go anywhere. The DNS still resolves, but instead of being NATed correctly it seems to get stuck in some kind of loop then the TTL expires.
When I ping the address from VLAN 1 or from my workstation, the TTL expires. So I did a traceroute this is what i found happens:
Thornton#traceroute mail.company.com.au
Tracing the route to mail.company.com.au (2XX.2XX.3X.193)
  1 10.20.20.187 16 msec 20 msec 52 msec
  2 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 36 msec 32 msec 36 msec
  3 10.20.20.187 36 msec 32 msec 32 msec
  4 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 52 msec 52 msec 52 msec
  5 10.20.20.187 52 msec 48 msec 52 msec
  6 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 68 msec 64 msec 68 msec
  7 10.20.20.187 68 msec 68 msec 68 msec
  8 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 88 msec 88 msec 88 msec
  9 10.20.20.187 84 msec 80 msec 84 msec
10 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 104 msec 108 msec 108 msec
11 10.20.20.187 96 msec 120 msec 100 msec
12 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 120 msec 116 msec 120 msec
13 10.20.20.187 116 msec 116 msec 132 msec
14 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 152 msec 144 msec 132 msec
15 10.20.20.187 152 msec 128 msec 136 msec
16 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 152 msec 168 msec 152 msec
17 10.20.20.187 152 msec 152 msec 152 msec
18 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 172 msec 164 msec 184 msec
19 10.20.20.187 168 msec 168 msec 168 msec
20 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 184 msec 192 msec 180 msec
21 10.20.20.187 208 msec 196 msec 188 msec
22 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 204 msec 220 msec 204 msec
23 10.20.20.187 201 msec 200 msec 216 msec
24 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 240 msec 236 msec 248 msec
25 10.20.20.187 224 msec 216 msec 284 msec
26 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 236 msec 256 msec 256 msec
27 10.20.20.187 232 msec 328 msec 232 msec
28 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 260 msec 248 msec 256 msec
29 10.20.20.187 252 msec 248 msec 252 msec
30 1XX-6XX-1XX-247.static.tpgi.com.au (1XX.6XX.1XX.247) 292 msec 268 msec 268 msec
i can see the the TTL is expiring from the packet going into an endless loop, but i don't know why it is doing it. or how i can stop it.   i would show you a copy of the "sh ip nat translations" output but the one i grabbed lastnight didn't contain any of the translations relevant to what we are talking about here. (I didn't scroll down far enough is all)
I was wondering what that 10.20.20.187was. so i did a sh ip route and found this:
Thornton#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     1XX.0.0.0/32 is subnetted, 1 subnets
C       1XX.6XX.1XX.247 is directly connected, Dialer0
     10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C       10.10.5.0/24 is directly connected, Vlan1
C       10.20.20.187/32 is directly connected, Dialer0
S*   0.0.0.0/0 is directly connected, Dialer0
Thornton#
10.20.20.187 seems to only appear once the PPP connection comes up so I assume that it has something to do with PPP.  The other address that is X'd out is the Static IP of our internet connection that gets assigned through PPP negotiation.
thanks so much for the help here guys. it is much appreciated.
Do you use debug ip nat comand when tracering?
GRinch
I haven't yet, but I will do it tonight when everyone goes home.
I have been looking around a bit at different appoaches to this problem, I had heard of NAT Virtual Interface and then i found this:
http://inetpro.org/wiki/NAT:_access_outside_global_address_from_the_inside
This sounds like it will fit my scenario pretty well. so im going to give this ago tomorrow. I'll report back hear what i find if it works.
Hi Kyle,
What you are trying to do is not supported on IOS Routers. See the notes below:
** When sitting on the inside LAN segment, you cannot access the internal server
using its Public NATted ip. This is a NAT limitation with routers. You will
have to use the private ip to access that server.
Ping to that Public Ip from inside host might work because Router will respond back for
that ping, not the actual server. And if we use "no-alias" keyword at the end of the static
NAT statement, then even this ping would stop working. And again, this is an expected
behaviour of router.
Possible workarounds to accomplish the above requirement i.e access the internal
server from the same LAN (pre-requisite for this is, use of FQDN to access the server.
By using the public ip, there is no way we can accomplish this):
1. Use one to one static NAT translation for the private ip of the server which will enable
DNS doctoring
2. Use an internal DNS server with the mapping of this website to the private ip
3. Change the host file on the PC's trying to access this server from inside (which generally
is not a feasible solution as there could be many hosts in LAN)
Ref:
https://supportforums.cisco.com/docs/DOC-8936
I hope this helps.
Raga
Luis Diego Raga wrote:
Hi Kyle,
Hi Luis,
Bugger! that isnt what I wanted to hear. but thems the breaks i guess. I'll just have to do it with split DNS zones. I would have thought that NVI would have solved my issue though? or is that not something that isn't used on IOS routers?
Yeah I know ....
About the NVI, I cant really tell as I've never configured or seen it working, perhaps it is worth giving it a try.
Here's another doc that talks about it:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t14/feature/guide/gtnatvi.html
Have a good one.
Raga
