NAT Port Forwarding Help
Cody Hay
Hello Everyone,
     If I'm sitting inside my network (192.168.1.0/24) and I type in an internet browser my global address with a port attached (50.50.50.50:5001) it says page cannot be displayed, but if i'm outside of my network and I use that same address the port forwarding works? How do I configure my router to be able to use the global address when i'm inside my network so i do not have to change my server settings in all my devices everytime I want to check my work orders while sitting at my desk?
Config:
interface FastEthernet0/0
ip address 50.50.50.50 255.255.224.0
ip verify unicast source reachable-via rx allow-default 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
speed 100
full-duplex
no keepalive
no mop enabled
interface FastEthernet0/1
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
speed 100
full-duplex
no keepalive
no mop enabled
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 50.50.50.x
ip nat inside source list 1 interface FastEthernet0/0 overload
ip nat inside source static tcp 192.168.1.10 5001 interface FastEthernet0/0 5001
ip nat inside source static tcp 192.168.1.10 5002 interface FastEthernet0/0 5002
access-list 1 permit 192.168.1.0 0.0.0.255
cadet alain
It should be working with NAT NVI:
int f0/1
no ip nat in
no ip redirect
ip nat enable
int f0/0
no ip nat out
ip nat enable
no ip redirect
no ip nat inside source list 1 interface FastEthernet0/0 overload
no ip nat inside source static tcp 192.168.1.10 5001 interface FastEthernet0/0 5001
no ip nat inside source static tcp 192.168.1.10 5002 interface FastEthernet0/0 5002
ip nat  source list 1 interface FastEthernet0/0 overload
ip nat  source static tcp 192.168.1.10 5001 interface FastEthernet0/0 5001
ip nat  source static tcp 192.168.1.10 5002 interface FastEthernet0/0 5002
Alain
Dennis Mink
you would need to confgure NAT hairpinning to be able to do that
alternatively DNS doctoring and changing lmhost file to you could fix this as well
Please remember to rate useful posts, by clicking on the stars below.
cadet alain
int f0/1
no ip nat in
no ip redirect
ip nat enable
int f0/0
no ip nat out
ip nat enable
no ip redirect
Alain
That works perfectly. Thanks! Now to understand why it works that way.
Much Appreciation!
