NAT problem with servers
srmumtaz01
hi,
i am hosting an application server at HO to which clients connect using the client application, using 2 ports.(8090,8092). We were using a DSL connection and eveyrthing was good.
Now we bought an E1, terminated it on 2811 using e1 controler card.I configured Nat with ports using SDM for application server. everything is fine, the internet is working good. clients started connecting but when the number of clients reach 3 or 4 then no more connections are made. i did not do any other configuration apar from NAT. i looked up debug ip tcp packets and it showed RST pakets being sent to client adds from my public ip. it doesnt show any tcp rst packet from the private ip of my application server. can any1 have any idea.
thanks
royalblues
Level 10
Level 10
can you post a sh run from the router?
Narayan
!This is the running config of the router: 10.10.10.1
!version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
resource policy
no network-clock-participate wic 0
ip cef
no ip domain lookup
username **** privilege 15 password 0 ********
controller E1 0/0/0
framing NO-CRC4
channel-group 2 timeslots 1-16
interface FastEthernet0/0
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip nat inside
duplex auto
speed auto
interface Serial0/0/0:2
ip address 203.126.130.195 255.255.255.252
ip nat outside
ip default-gateway 203.126.130.194
ip route 0.0.0.0 0.0.0.0 203.126.130.194
ip http server
ip http authentication local
no ip http secure-server
ip nat inside source list 1 interface Serial0/0/0:2 overload
ip nat inside source static tcp 192.168.1.3 8092 interface Serial0/0/0:2 8092
ip nat inside source static tcp 192.168.1.3 8091 interface Serial0/0/0:2 8091
ip nat inside source static tcp 192.168.1.3 8090 interface Serial0/0/0:2 8090
ip nat inside source static tcp 192.168.1.3 80 interface Serial0/0/0:2 80
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
scheduler allocate 20000 1000
end
