OSPF metrics and how it is determined
wilson_1234_2
Level 3
Level 3
I have a lab setup with a router, layer three 3550 switch and a PIX firewall.
The router and the firewall are plugged into the switch in seperate VLANs and are using the switch as their default gateway.
All three devices are configured in the same OSPF area, I am using almost identical configs from a production network an I see the same results.
All interfaces are Fastethernet 100/full
I would like to understand how the OSPF metrics are determined for this setup.
For example:
The switch sees the PIX and router as Full/BDR state and the Router's loopback interface as 110/2. Is it 2 because it is considered not directly connected but 1 hop away?
The switch sees the firewall DMZ interface as the neibor ID and as 110/11.
Why is the metric 11?
The router sees the PIX inside interface as 110/2, and the PIX DMZ as 110/12. Because same as above, considered 1 hop away from the connected interface?
Firewall:
router ospf 2
network 10.1.3.0 255.255.255.0 area 0 (inside)
network 192.168.1.0 255.255.255.0 area 0 (DMZ1)
redistribute ospf 1 subnets match internal external 1 external 2
default-information originate
Switch:
router ospf 1
log-adjacency-changes
passive-interface Vlan1
passive-interface Vlan2
passive-interface Vlan3
passive-interface Vlan4
network 0.0.0.0 255.255.255.255 area 0
Router:
router ospf 1
router-id 10.5.7.1
passive-interface Loopback0
network 10.1.7.0 0.0.0.255 area 0 (Ethernet interface on inside)
network 172.16.0.1 0.0.0.0 area 0 (Loopback0)
5 Replies 5
Jon Marshall
Hi Wilson
OSPF does not use hop count as it's routng metric. It use the bandwidth of the interface.
The actual calucaltion is reference bandwidth / bandwidth of interface.
To key it simple the refernce bandwidth is 10 to the power 8. So
fast ethernet = 10 power 8 / 10 power 8 = 1
ethernet = 10 power 8 / 10 power 7 = 10
So the switch sees the cost ot the firewall DMZ interface as
1 ( for the cost of the link from the switch to the inside interface of the pix )
10 for the cost of the DMZ interface
This assumes that the firewall DMZ is running as normal ethernet ie. 10 rather than fast-ethernet ie. 100.
Is this the case ?
Jon
Thanks Jon,
The cost on the interfaces are as follows:
The cost on the PIX is 10
The cost on the router 1
This is what is calculated from the numbers you gave?:
Ethernet 10
Fastethernet 100
Also, on the bandwidth: suppose the bandwidth xxxx command has not been configured as part of the interface by the person configuring the router. How is it determined by OSPF on say a serial interface where you could have a DS1 or a DS3?
Also why does the PIX show the neighbor address as the DMZ interface and not the inside ethernet address?
On a serial interface, the hardware determines the default bandwidth. If you have a DS1 card, the hardware will be shown as 1.5Mbps under the interface (type show interface s0/0 and you will see the bandwidth information).
Same goes for a DS3 card.
minumathur
OSPF Cost will be calculated based on 10 power 8 / Bandwidth.
-Minu
rajinikanth
Level 3
Level 3
Hi Wilson,
Firewalls ospf router-id is DMZ1 (192.168.1.0) because it is the highest configure ip address on firewall.
This is the reason you find in switch the neighbor id (192.168.1.0) instead of 10.1.3.0 inside ntw.
HTH,
Raj
