NAT Problems
johnakeating
I am setting up a router that has a T1 and a DSL link
I have configured the interfaces and put the outside and inside for the correct interfaces but I can only get nat working on the T1. I feel as if maybe the router is using to T1 line IP address when trying to send to the DSL and the ISP does not accept them.
interface Loopback1
ip address XX.XX.144.66 255.255.255.192
interface Loopback2
no ip address
interface FastEthernet0/0
description ####### TO DISTRICT LAN ########
no ip address
duplex auto
speed auto
interface FastEthernet0/0.2
description DMZ
encapsulation dot1Q 2
ip address 10.1.1.4 255.255.0.0
ip nat inside
no snmp trap link-status
interface FastEthernet0/0.20
encapsulation dot1Q 20
ip address 172.16.1.2 255.255.0.0
ip nat inside
interface FastEthernet0/1
ip address xx.xx.12.4 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/1/0
description T1
ip address xx.xx.159.162 255.255.255.252
ip nat outside
encapsulation ppp
ip route 0.0.0.0 0.0.0.0 XX.XX.12.1
ip route 10.0.0.0 255.0.0.0 10.1.1.1
ip route XX.XX.129.32 255.255.255.240 XX.XX.159.161
ip nat pool DSLPOOL xx.xx.12.175 XX.XX.12.179 netmask 255.255.255.0
ip nat pool T1POOL xx.xx.144.65 XX.XX.144.126 netmask 255.255.255.192
It seems as if I can not have both of these running at the same time. The ACL matches both and then only allows the T1.
How do I run two different NAT on the same router?
ip nat inside source list 2 interface Loopback1 overload
ip nat inside source list 3 interface FastEthernet0/1 overload
lejoe.thomas
Level 3
Level 3
Hi John,
You need use route-maps to match NAT ACLs to the appropriate outside interface.
route-map T1
match ip address 1
match interface s0/1/0
route-map DSL
match ip address 2
match interface FastEthernet0/1
ip nat inside source route-map T1 interface Loopback1 overload
ip nat inside source route-map DSL interface FastEthernet0/1 overload
Also add a default-route through the T1 link.
Consider reading the paper below as well
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
Lejoe
