NAT Query
jonhowell
I have a VPN between two sites and would like to forward a particular port to an IP address at the remote site
Is there a way of forwarding the traffic that comes down the vpn tunnel destined for IPAdressA(Portx) to IPAddressB(Portx)
The IP addresses are internal adresses i.e. 172.16.0.1 and 172.16.0.2
Hope that makes some sense
Thanks in advance
Danilo Dy
Have you check port redirection? I use this all the time to bypass something that doesn't work where it should be http://www.cisco.com/warp/public/707/28.html#topic9
But I haven't tried this accross VPN tunnel.
Dandy
