Should I use DH Group 5 with AES-256/SHA?
whiteford
Hi, When I trying create a VPN on my Cisco ASA it says I should use GH Grop 5, I normally use 2, is this more secure or faster than?
JORGE RODRIGUEZ
Level 10
Level 10
From what I understand Group 5 is the default choice when using AES encryption algorythm, and yes it provides more security than group1 and group2, I don't have a link but I read while back G5 is mostly choosen when implementing L2L connections or vpn clients using certificates. If this is a L2L connection you are working on make sure the other end is also set as such.
http://www.cisco.com/en/US/docs/ios/12_1t/12_1t3/feature/guide/dtgroup5.html
Rgds
Jorge
Jorge Rodriguez
Thanks Jorge,
I can't get DH5 to work, but you say it's using certs which I don't have, DH2 works fine though.
I set the Cisco 877 routers IKE proposal to use AES-256/SHA and it uses AES-128 instead although the IPsec tunnel uses AES-256/SHA, could there be a reason for this?
Can you post your config?
Dandy
