NAT static with inside Proxy IP
rkrumpe
i want NAT from outside to inside. This works fine so the inside Station (Web-Server) have an Default-Gateway to my NAT-Routers inside Interface-IP.
I want NAT from Outside-IP 213.1.1.1 to Inside-Station 192.168.235.56 and the originator-IP should be the Interface-IP 192.168.235.60 from Router.
So the Web-Server recognise the packet within the same Subnet and can respond to this.
How can i solve this?
regards
Ronny
Case Cisco:
int e0/0
ip add 213.1.1.5 255.255.255.240
ip nat outside
int e0/1
ip add 192.168.235.60 255.255.255.240
ip nat inside
ip nat inside source static tcp 192.168.235.56 80 213.1.1.1 80
Giuseppe Larosa
Hello Ronny,
well, an ip default gateway on the web server should be already present so the source address shouldn't be a problem.
unless you need to translate also the source in that case
ip nat outside source
can be useful
see
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_nat.html#wp1011984
Hope to help
Giuseppe
