Bookmark
Subscribe
1064
PIM Sparse Mode Join Load Balance
cannone78
Hi all,
By default, PIM join messages are sent toward a source based on the RPF routing table check. If there is more than one equal-cost path toward the source, then one upstream interface is chosen to send the join message and add to the multicast data tree. This interface is also used for all downstream traffic, so even though there are alternatives interfaces available, the multicast load is concentrated on one upstream interface and router.
In cisco IOS, For PIM sparse mode, is it possible configure PIM join load balancing to spread join messages and traffic across equal-cost upstream paths (interfaces and routers) provided by unicast routing towards a source?
Many thanks in advance for your support
Gianluca
Giuseppe Larosa
Hello Gianluca,
try to see the following
ip multicast [vrf vrf-name] multipath [s-g-hash {basic | next-hop-based}]
http://www.cisco.com/en/US/docs/ios/ipmulti/command/reference/imc_03.html#wp1052965
Hope to help
Giuseppe
Giuseppe Larosa
Hello Gianluca,
Hope to help
Giuseppe
Many thanks Giuseppe!
Buon weekend
Gianluca
