11-04-2019 06:11 AM - edited 11-04-2019 06:15 AM
We have an ISR4321/k9 installed at one of our colo's and it's been working just fine for the better part of two months. recently we started having issues with traffic suddenly not getting through. I can still telnet into the router from an external IP, and the server logs show that the servers on the inside never lost internet connectivity (though I'm not sure if we have a great litmus test in place for this), but nothing outside can connect to the servers.
we're using nat to translate a set of public IPs and ports to the local IPs, so I figured this was part of the problem. google told me to check the logs and I found this:
*Oct 29 18:58:21.459: %IOSXE-4-PLATFORM: SIP1: cpp_cp: QFP:0.0 Thread:000 TS:000 00015964780136856 %NAT-4-DEFAULT_MAX_ENTRIES: default maximum entries value 131072 exceeded; frame dropped
Google also told me to run the following commands to resolve the issue:
# ip nat translation max-entries 247483647 # clear ip nat translation *
Those seemed to do the trick and we opted to subscribe to a domain checking service to monitor the site for outages. Things ran for almost a week without incident!
...this morning, I woke up with my inbox blown to pieces and the site down again.
Logged in and ran sh log, but I didn't see anything new... I didn't even see myself logging in! I should have cleared the log, waited a minute and checked again, but I went ahead and ran clear ip nat translation *, and of course the site immediately came back online, so I'm pretty sure the NAT translation table filled up again.
I'm fairly familiar with cisco switches, but routing is a new beast for me so I'm pretty out of my depth on this one.
What do I need to do to stop this from happening?
In case it's useful, here's my running config:
colo-net1#sh run Building configuration... Current configuration : 4317 bytes ! ! Last configuration change at 16:21:57 UTC Fri Nov 1 2019 ! version 15.5 service timestamps debug datetime msec service timestamps log datetime msec no platform punt-keepalive disable-kernel-core ! hostname colo-net1 ! boot-start-marker boot-end-marker ! ! vrf definition Mgmt-intf ! address-family ipv4 exit-address-family ! address-family ipv6 exit-address-family ! enable secret 5 [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] enable password [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] ! no aaa new-model ! transport-map type persistent webui https-webui secure-server ! transport-map type persistent webui http-webui server ! transport-map type persistent webui http-https-webui server secure-server ! ! ! ! ! ! ! ! ! ! ! ! ip name-server 208.67.222.222 ! ip dhcp pool 1 utilization mark high 80 log utilization mark low 70 log network 192.168.60.0 255.255.255.0 domain-name int.pos.ac default-router 192.168.60.1 dns-server 208.67.222.222 8.8.8.8 lease 30 class CLASSC address range 192.168.60.240 192.168.60.250 ! ! ip dhcp class CLASSC ! ! ! ! ! ! ! ! ! subscriber templating multilink bundle-name authenticated ! ! ! crypto pki trustpoint TP-self-signed-1403732793 enrollment selfsigned subject-name cn=IOS-Self-Signed-Certificate-1403732793 revocation-check none rsakeypair TP-self-signed-1403732793 ! ! crypto pki certificate chain TP-self-signed-1403732793 license udi pid ISR4331/K9 sn [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] ! spanning-tree extend system-id ! username vadmin privilege 15 secret 5 [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] ! redundancy mode none ! ! vlan internal allocation policy ascending ! ! ! ! ! ! interface GigabitEthernet0/0/0 description WAN000 ip address XXX.XXX.XXX.37 255.255.255.240 secondary ip address XXX.XXX.XXX.38 255.255.255.240 secondary ip address XXX.XXX.XXX.39 255.255.255.240 secondary ip address XXX.XXX.XXX.40 255.255.255.240 secondary ip address XXX.XXX.XXX.41 255.255.255.240 secondary ip address XXX.XXX.XXX.42 255.255.255.240 secondary ip address XXX.XXX.XXX.43 255.255.255.240 secondary ip address XXX.XXX.XXX.44 255.255.255.240 secondary ip address XXX.XXX.XXX.45 255.255.255.240 secondary ip address XXX.XXX.XXX.46 255.255.255.240 secondary ip address XXX.XXX.XXX.36 255.255.255.240 ip nat outside negotiation auto ! interface GigabitEthernet0/0/1 ip address 192.168.61.1 255.255.255.0 negotiation auto ! interface GigabitEthernet0/0/2 no ip address shutdown negotiation auto ! interface GigabitEthernet0/1/0 ! interface GigabitEthernet0/1/1 ! interface GigabitEthernet0/1/2 ! interface GigabitEthernet0/1/3 ! interface GigabitEthernet0/1/4 ! interface GigabitEthernet0/1/5 ! interface GigabitEthernet0/1/6 ! interface GigabitEthernet0/1/7 ! interface GigabitEthernet0 vrf forwarding Mgmt-intf ip address 192.168.60.3 255.255.255.0 negotiation auto ! interface Vlan1 ip address 192.168.60.1 255.255.255.0 ip nat inside ! ip nat translation timeout 86400 ip nat translation max-entries 247483647 ip nat pool NAT1 XXX.XXX.XXX.36 XXX.XXX.XXX.36 netmask 255.255.255.240 ip nat inside source static 192.168.60.11 XXX.XXX.XXX.39 extendable ip nat inside source static 192.168.60.21 XXX.XXX.XXX.40 extendable ip nat inside source static 192.168.60.119 XXX.XXX.XXX.41 extendable ip nat inside source static 192.168.60.120 XXX.XXX.XXX.42 extendable ip nat inside source static 192.168.60.121 XXX.XXX.XXX.43 extendable ip nat inside source static 192.168.60.122 XXX.XXX.XXX.44 extendable ip nat inside source static 192.168.60.123 XXX.XXX.XXX.45 extendable ip nat inside source static 192.168.60.124 XXX.XXX.XXX.46 extendable ip nat inside source static udp 192.168.60.11 1195 interface GigabitEthernet0/0/0 1195 ip nat inside source static udp 192.168.60.5 1192 interface GigabitEthernet0/0/0 1192 ip nat inside source static udp 192.168.60.5 1194 interface GigabitEthernet0/0/0 1194 ip nat inside source static tcp 192.168.60.11 10000 interface GigabitEthernet0/0/0 10000 ip nat inside source list 1 interface GigabitEthernet0/0/0 overload ip forward-protocol nd no ip http server no ip http secure-server ip route 0.0.0.0 0.0.0.0 XXX.XXX.XXX.33 ! ! access-list 1 permit 192.168.60.0 0.0.0.255 ! snmp-server community public RO ! ! control-plane ! ! line con 0 password [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] login stopbits 1 line aux 0 stopbits 1 line vty 0 4 password [XXXXXXXXXXXXXXXXXXXXXXXXXXXXX] login ! transport type persistent webui input https-webui ! ! end
11-04-2019 06:38 AM - edited 11-04-2019 06:38 AM
As pet bug of the defective, they suggested other parameters also change :
ip nat translation tcp-timeout 3600
ip nat translation udp-timeout 300
ip nat translation icmp-timeout 30
ip nat translation dns-timeout 10
ip nat translation syn-timeout 5
do clear ip nat translations *
and keep monitor #show platform hardware qfp active feature nat datapath door
11-04-2019 07:20 AM
on a side note, to remedy the problem, you could run an EEM script that would clear the NAT translation table automatically each day at midnight:
event manager applet CLEAR_NAT
event timer cron con-entry "0 0 * * *" maxrun 9999999
action 1.0 cli command "enable"
action 2.0 cli command "clear ip nat translation *"
action 3.0 cli command "end"
11-04-2019 07:50 AM
There's no timeout/ script that really can help until you do not understand exactly the problem at its roots.
With that being said i would focus my attention on connection type.
Routers/switches are built with their memory and hardware, so they come unfortunately with finite resources.
If your nat table saturate so fast:
1 - you may have a lot of visitors, so NAT entries does not comply with NAT session resources available on your device.
2 - it can be an attack which is exhausting your nat resources.
Check terminating connections on your servers to see if they're established, half-open or something else...
Do you have a FW behind your router? or servers are connected directly behind the ISR4k ?
