NAT with bridge and failover issue
crashdump
I have two ISP, the main on Dialer0 and the backup on Fa0/1,
I have setup an ip sla on the ADSL link to check if he's up
or not and then fallback on the second provider link (fa0/1).
Everything works well when the ADSL is down (when the nat goes
through the backup link) but as soon as the ADSL is ok the
NAT doesn't want to work. I've tried to nat overload on BVI1
or on Dialer0 (where I use to do when there were no bridge)
it makes no differences
I've already done a lot of theses setups with two isp and it
works well but without the bridge (and I  realy need it here)
Thank you !
FastEthernet0/0            : LAN (nat inside) - Here I plug my laptop with ip 10.0.0.2/24
FastEthernet0/1            : Backup WAN (nat outside)
Dialer0                    : Main WAN (nat outside)
FastEthernet0/1/0 - 3      : WAN Bridge Dialer0
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-25e.bin
boot-end-marker
ip cef
ip sla monitor 1
type pathEcho protocol ipIcmpEcho 8.8.4.4
timeout 1000
threshold 3
ip sla monitor schedule 1 life forever start-time now
ip sla monitor 2
type pathEcho protocol ipIcmpEcho 109.159.248.158
timeout 1000
frequency 3
ip sla monitor schedule 2 life forever start-time now
track 1 rtr 1 reachability
track 2 rtr 2 reachability
track 101 list boolean or
object 1
object 2
bridge irb
interface FastEthernet0/0
description LAN /w NAT inet and failover
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
description Demon's network 193.195.220.x
ip address 193.195.220.236 255.255.255.240
ip nat outside
duplex auto
speed auto
interface FastEthernet0/2/0
switchport access vlan 2
interface FastEthernet0/2/1
interface FastEthernet0/2/2
interface FastEthernet0/2/3
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
atm restart timer 300
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0/1/0.1 point-to-point
pvc 0/38
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface Vlan1
no ip address
interface Vlan2
description BT's network 217.36.70.x
no ip address
no ip unreachables
ip tcp adjust-mss 1452
bridge-group 1
interface Dialer0
ip unnumbered BVI1
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin
ppp chap hostname XXXXXXXXXX
ppp chap password 7 XXXXXXXXXX
ppp pap sent-username XXXXXXXXX password 7 XXXXXXXXXX
interface BVI1
ip address 217.36.70.157 255.255.255.248
ip nat outside
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0 track 101
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 193.195.220.225 250
ip route 8.8.4.4 255.255.255.255 Dialer0
ip route 109.159.248.158 255.255.255.255 Dialer0
ip nat inside source route-map isp1 interface BVI1 overload
ip nat inside source route-map isp2 interface FastEthernet0/1 overload
ip access-list extended LAN_RANGE
permit ip 10.0.0.0 0.0.0.255 any
route-map isp2 permit 10
match ip address LAN_RANGE
match interface FastEthernet0/1
route-map isp1 permit 10
match interface BVI1
control-plane
bridge 1 protocol ieee
bridge 1 route ip
end
25 Replies 25
What is the default gateway address fro "main wan" ? It need to be configured as defafult route.
Ok, the gateway is 217.32.141.129, so i've set
ip route 0.0.0.0 0.0.0.0 Dialer0 217.32.141.129
ip default-gateway 217.32.141.129
but still doesn't work. I can't ping 217.36.70.157 from a laptop on a Fe0/2/x int
Here is my updated config for information:
version 12.4
ip cef
(snipped track stuff here)
ip nat inside
ip nat outside
interface ATM0/1/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
pvc 0/38
interface Vlan1
no ip address
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp chap hostname xxx
ppp chap password 7 xxx
ppp pap sent-username xxx password 7 xxx
ip nat inside source route-map isp1 interface Dialer0 overload
match interface Dialer0
end
Again, if you have regular etherner connection, dialer do not apply, and vice-versa.
Please clarify and post here all the connection details as have been given to you by ISP.
Here is a small explanation, I hope you will understand better like that
                        ____________
LAN (nated access to --|- Fa0/0     |
internet 10.0.0.0/24)  |            |
                       |     Fa0/1 -|-- (193.195.220.236)
                       |            | --Provider backup ----->
                       |            | ----- Main ISP ------>
                       |  ATM0/1/0 -|-- (217.36.70.157) ADSL PPPoE
                       |            |    217.36.70.152/29
                       |            |   (GW: 217.32.141.129)
Servers on the BT's  --|- Fa0/2/0-3 |
      Subnet           |____________|
I'll use the 10.0.0.0/24 network for computers to access internet through NAT
I'll use the 4 port WIC module to connect some servers directly on the main isp network
NAT will failover on the Fa0/1 if the ADSL is down.
I understand all that. I was thinking you had ethernet from BT, now I realize you have ADSL instead.
The next question is if BT give you a separate address for terminating PPP, let assume for now they don't.
So based on the last config you sent, change:
interface Vlan1
interface Dialer0
ip unnumbered vlan1
ppp ipcp route default
no ip route 0.0.0.0 0.0.0.0 Dialer0 217.32.141.129
And please take "debug ppp neg" with "term mon" when you connect ADSL
Ok, here is the result:
*Jul 25 13:06:19.887: Vi2 CHAP: I SUCCESS id 1 len 43 msg is "CHAP authentication success, unit 14144"
*Jul 25 13:06:19.887: Vi2 PPP: Phase is FORWARDING, Attempting Forward
*Jul 25 13:06:19.887: Vi2 PPP: Queue IPCP code[1] id[204]
*Jul 25 13:06:19.887: Vi2 PPP: Phase is ESTABLISHING, Finish LCP
*Jul 25 13:06:19.887: Vi2 PPP: Phase is UP
*Jul 25 13:06:19.887: Vi2 IPCP: O CONFREQ [Closed] id 1 len 10
*Jul 25 13:06:19.887: Vi2 IPCP:    Address 217.36.70.157 (0x0306D924469D)
*Jul 25 13:06:19.887: Vi2 PPP: Process pending ncp packets
*Jul 25 13:06:19.887: Vi2 IPCP: Redirect packet to Vi2
*Jul 25 13:06:19.887: Vi2 IPCP: I CONFREQ [REQsent] id 204 len 10
*Jul 25 13:06:19.887: Vi2 IPCP:    Address 217.32.141.129 (0x0306D9208D81)
*Jul 25 13:06:19.887: Vi2 IPCP: O CONFACK [REQsent] id 204 len 10
*Jul 25 13:06:19.891: Vi2 IPCP:    Address 217.32.141.129 (0x0306D9208D81)
*Jul 25 13:06:19.915: Vi2 IPCP: I CONFNAK [ACKsent] id 1 len 10
*Jul 25 13:06:19.915: Vi2 IPCP:    Address 86.140.19.226 (0x0306568C13E2)
*Jul 25 13:06:19.915: Vi2 IPCP: O CONFREQ [ACKsent] id 2 len 4
*Jul 25 13:06:19.943: Vi2 IPCP: I CONFNAK [ACKsent] id 2 len 10
*Jul 25 13:06:19.943: Vi2 IPCP:    Address 86.140.19.226 (0x0306568C13E2)
*Jul 25 13:06:19.943: Vi2 IPCP: Ignoring unrequested options!
*Jul 25 13:06:19.943: Vi2 IPCP: O CONFREQ [ACKsent] id 3 len 4
*Jul 25 13:06:19.967: Vi2 IPCP: I CONFACK [ACKsent] id 3 len 4
*Jul 25 13:06:19.967: Vi2 IPCP: State is Open
*Jul 25 13:06:19.971: Di0 IPCP: Install default route thru 217.32.141.129
*Jul 25 13:06:19.971: Di0 IPCP: Install route to 217.32.141.129
*Jul 25 13:06:19.971: Vi2 IPCP: Add link info for cef entry 217.32.141.129
*Jul 25 13:06:20.399: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0/0, changed state to up
Thanks.
I think that BT wants you have "ip address negotiated" under dialer0, however can you now ping 217.32.141.129 from router or devices on vlan 1 ?
Said devices will have default-gateway 217.36.70.157 and must be able to ping it.
Everything work but the NAT. It's odd.
I start to think it's not feasible.
Can you try
int dialer0
ip address negotiated.
No other changes.
It work. Thank you a lot Paolo !
Finally you were right, with "ip address negotiated"  BT assigned me a completelly different ip on the dialer. The subnet also  works nice and this way the router is not lost anymore with the NAT.  Brilliant !
Where does I send the coffee ?
Again, thank you.
Here  is the final complete config with all the stuff for the nat, sla  failover, etc (It's for information is someone need it one day, like me)
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname inet-failover-rt
boot-start-marker
boot-end-marker
logging buffered 51200 debugging
logging console critical
enable secret 5 XXXXXXXXXX
no aaa new-model
ip cef
no ip bootp server
no ip domain lookup
ip domain name aac-services.co.uk
ip name-server 62.6.40.162
ip name-server 194.74.65.69
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
ip sla monitor 1
timeout 999
threshold 500
owner GOOGLE DNS
frequency 2
ip sla monitor 2
type pathEcho protocol ipIcmpEcho 193.0.14.129
timeout 999
threshold 500
owner RIPE DNS
frequency 2
username admin privilege 15 password 7 XXXXXXXXXX
archive
log config
  hidekeys
ip tcp synwait-time 10
ip ssh authentication-retries 2
ip ssh logging events
ip ssh version 2
track 3 interface ATM0/2/0 line-protocol
track 10 list boolean or
object 1
object 2
track 101 list boolean and
object 3
object 10
track 102 interface FastEthernet0/1 line-protocol
description ***** LAN ******
ip address 10.10.10.1 255.255.255.0
ip access-group FW-LAN-IN in
ip access-group FW-LAN-OUT out
ip nat inside
duplex auto
speed auto
description ***** Demon's Backup Broadband *****
ip nat outside
duplex auto
speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
interface FastEthernet0/0/2
interface FastEthernet0/0/3
interface ATM0/2/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface ATM0/2/0.1 point-to-point
pvc 0/38
interface Vlan1
description ***** BT network *****
interface Dialer0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
ip route-cache flow
dialer pool 1
dialer-group 1
no cdp enable
ppp pap sent-username XXXXXXXXXX password 7 XXXXXXXXXX
ip default-gateway 217.36.70.157
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1 193.195.220.225 250 track 102
ip route 193.0.14.129 255.255.255.255 Dialer0
no ip http server
no ip http secure-server
ip nat inside source route-map ISP_1 interface Dialer0 overload
ip nat inside source route-map ISP_2 interface FastEthernet0/1 overload
ip access-list extended FW-LAN-IN
permit icmp any any
permit tcp any gt 1024 any eq 22
permit tcp any gt 1024 any eq www
permit tcp any gt 1024 any eq 443
permit tcp any gt 1024 any eq domain
permit udp any gt 1024 any eq domain
deny   ip any any log
ip access-list extended FW-LAN-OUT
permit icmp any any
permit tcp any eq 22 any gt 1024
permit tcp any eq www any gt 1024
permit tcp any eq 443 any gt 1024
permit tcp any eq domain any gt 1024
permit udp any eq domain any gt 1024
permit ip 10.10.10.0 0.0.0.255 any
route-map ISP_1 permit 10
route-map ISP_2 permit 10
control-plane
line con 0
line aux 0
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
scheduler allocate 20000 1000
end
We should have tried that at the beginning, it's a common configuration.
Thank you for the nice rating and good luck!
