DHCP Snooping not logging violations
tjreeddoc
I have a Cisco 3750E-24TD running 12.2(55)SE10 and ip dhcp snooping enabled. However, I am not getting any DHCP Snooping messages when a rogue DHCP Server tries to respond dhcp discovery broadcast.
Turning on debug ip dhcp snooping packet and debug ip dhcp snooping events, I do see the following message:
DHCP_SNOOPING_SW: bridge packet output port is null, packet is dropped.
Has anyone received Syslog messages from a Cisco 3750E-24TD with ip dhcp snooping enabled? If so, what IOS were you running?
T.J.
sushanth.shetty
I always had hard time in getting the DHCP snooping, DHCP binding and NAT translation logs to syslog.
You may have to enable debugging for dhcp snooping and set the logging trap to debugging to get the logs on syslog server
logging trap debugging
You can also try to use smartlog which is used to send the contents to a NetFlow collector. I'm not really sure if it works for syslog though
Switch(config)# ip dhcp snooping vlan x smartlog
