Need a router having following features
jachowda
Hi all,
I need arouter that will be haivng all the features that i am listing below.
1.Multi Processor Architecture
2.Two synchronous WAN port with DTE speeds upto 2.048 MBPS should connect to fractional E1 (G.703)
3.One Ethernet LAN connection 10 Base-T
4.Inbuilt CSU/DSU
5.Flash Memory 2 MB
6.SRAM 6 MB
7.LED's for WAN and LAN status
8.RS-232 interface for local configuration
9.Software Upgradeable
10.CAM (16 Kilo Words) based Router Accelerator Mobile
11.Long Haul E1
12.Class 5 Telecommunication Grade Design
13.Complaint to TEC-QM-333 specification.
14.Convention cooling, no forced cooling
15.19 inch Rack mount design
16.Operating Voltage -48 V DC
17.Operational as per Installation diagram in Drop Insert Mode
18.Make: RAD
Please help me in sloving this case.
paolo bevilacqua
That's an easy bid to answer, look at point 18 and search among products of that manufacturer, not cisco.
you can consult your boss to isolate some lists that are not related to Cisco products!
