Need an ios for supervisor Iv engine
aaronhill1
Does anyone know what ios i can run on my supervisor Iv engine. I just bought it and they did not send the flash with it. I have IOS for Supervisor 720,sup32 on hand right now..
The IV engine is going in a 4500 chassis and needs to be able to support up to a 48 port sfp card as well as many others.
Leo Laohoo
Read the Release Notes.  The Release Notes will contain details of open/closed/solved bugs as well as the different line cards supported by each IOS train.
ghostinthenet
Level 7
Level 7
The Catalyst 4500 Supervisor IV uses the switch IOS SG images. The latest release for that platform is cat4500-ipbasek9-mz.150-2.SG8.bin and can be downloaded via the Cisco web site. This release will support a WS-X4248-FE-SFP 48-port SFP-based line card with no trouble. If you have the WS-X4748-SFP-E line card, you're going to need to use newer supervisor because there's no switch IOS image for the supervisor IV that supports it.
Jody Lemoine, Network Architect
CCIE 41436, MTCRE, MTCINE, MTCIPv6E
tishco networks, Virtually Everywhere
(905) 378-1134, jody.lemoine@tishco.ca
Thank you so much Jody, I do not have access through my account to download images through the site. The supervisor had a FE-SFP in it.. What Model would i need to run a WS-X4748-SFP-E?
If you set up a free account at CCO, I believe that is enough for access to download the base software images without a contract. For the WS-X4748-SFP-E you need a 4500E chassis and a supervisor 7L-E, 7-E or 8-E; and switch IOS 15.2.1E.
