06-23-2022
02:49 PM
- last edited on
06-29-2022
10:52 AM
by
Translator
I have a connection like below:
So I have a network connection like this. I am trying to get my PC connected to VLAN 50. However, I am not getting any connection and can not ping the gateway. I can not ping gateway even from L3 Switch 2 to VLAN interface of L3 Switch 1. Please advice.
All the link to core and switches are working and advertised in ospf on both end. I can connect PC to switch 1 and it works. I tried
Ip default gateway <VLAN 50 Interface IP>
on switch 2 but that did not work.
Solved! Go to Solution.
06-29-2022 08:42 AM
Issue fixed.
It was related to below issue:
LACP failing between 2 C9500-16X switches
Basically, both switches had the same mac and it created an issue with stp where both became root and one side of the trunk was blocked.
06-23-2022
03:04 PM
- last edited on
06-29-2022
10:55 AM
by
Translator
Switch 1 to Switch 2 Layer 2 connection Only, then PC connected port below to access port vlan 50, then PC able to ping the gateway.
From switch1 , so you see
arp table show IP arp
( do you see ARP entry of PC?)
Can you post the below information from switch 1 and switch 2
show vlan
show IP interface brief
show run interface x/x (trunk port config)
Pc - connected port show run interface x/x
06-27-2022
11:35 AM
- last edited on
06-29-2022
10:57 AM
by
Translator
From Sw1, I see arp but it shows incomplete.
Internet 10.150.5.5 0 Incomplete ARPA
Sh vlan:
VLAN Name Status Ports
50 V50_Mgmt active Te1/0/8, Te1/0/9
Trunk:
interface TenGigabitEthernet1/0/14
switchport trunk allowed vlan 50
switchport mode trunk
end
Int bri:
Te1/0/9 unassigned YES unset up up
PC Port:
interface TenGigabitEthernet1/0/9
switchport access vlan 50
switchport mode access
end
Sh int trunk:
Te1/0/14 on 802.1q trunking 1
Port Vlans allowed on trunk
Te1/0/14 50
Port Vlans allowed and active in management domain
Te1/0/14 50
Port Vlans in spanning tree forwarding state and not pruned
Te1/0/14 none
06-28-2022
03:02 AM
- last edited on
06-29-2022
10:58 AM
by
Translator
here is my observervation :
as per the PC IP 10.10.50.5 - but you mesage below :
Internet 10.150.5.5 0 Incomplete ARPA <<<<- is this correct IP ?
if you have Trunk, one of the reply what is the blocked ? that means you have spanning loop in the network, that is the reason PC not able to reach the gateway.
becuase they are not communicating each other, VLAN 50 root on both the switches ?
06-28-2022
09:29 AM
- last edited on
06-29-2022
10:59 AM
by
Translator
I copied the wrong line. Here is the line.
Internet 10.10.50.5 0 Incomplete ARPA
This VLAN is just on these two switches. How can there be a loop? Any idea how to fix?
This VLAN 50 is not trunked up to the Core. The switches and core links just have the p2p vlan 3100/3200.
06-28-2022
10:09 AM
- last edited on
06-29-2022
11:33 PM
by
Translator
show spanning block - from both the switches ?
check below your output :
Switch 1:
VLAN050
Spanning tree enabled protocol rstp
Root ID Priority 32871
Address 0001.0202.aabb
This bridge is the root
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32871 (priority 32768 sys-id-ext 50)
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Te1/0/9 Desg FWD 4 128.9 P2p
Te1/0/14 Desg FWD 2 128.14 P2p
Switch 2:
VLAN050
Aging Time 300 sec
Te1/0/14 Back BLK 2 128.14 P2p
06-23-2022
03:07 PM
- last edited on
06-29-2022
11:02 AM
by
Translator
Hi there,
What is the output of
sh spanning-tree vlan 50
and
sh mac-address-table vlan 50
on the two L3 switches? What does the switchport config look like on the port the PC is connected to? What is the MAC address of the PC?
cheers,
Seb.
06-27-2022
11:40 AM
- last edited on
06-29-2022
11:03 AM
by
Translator
Switch 1:
VLAN050
Aging Time 300 sec
Switch 2:
VLAN050
Aging Time 300 sec
06-27-2022 12:34 PM
Both switches are claiming to be the root switch which isn't right.
Also from your previous post showing the trunk link (on switch 2 ?) vlan 50 is not forwarding on te1/0/14 which I assume is the connection to switch 1 ?
Have you allowed vlan 50 on switch 1 trunk link ?
Jon
06-27-2022
02:06 PM
- last edited on
06-29-2022
11:04 AM
by
Translator
Yes, te1/0/14 is the interlink. Here is output from both switches:
Switch 1:
Port Mode Encapsulation Status Native vlan
Te1/0/1 on 802.1q trunking 1
Te1/0/14 50
Te1/0/14 50
Te1/0/14 50
Switch 2:
Te1/0/14 50
Te1/0/14 50
Te1/0/14 none
06-29-2022 08:42 AM
Issue fixed.
06-29-2022 04:22 AM
Hi there,
Can you confirm the physical connection for Switch2 Te1/0/14. The STP output shows this port as a BACKUP port which indicates that it is receiving its own BPDU which we can assume is being sent via Te1/0/9 .
cheers,
Seb.
06-23-2022 03:13 PM
Did you create vlan 50 on switch 2 and switch 1? command 'vlan 50'
06-27-2022 11:38 AM
Yes
