Need Help With NAT 2811 Router
OwenB
I am currently trying to configure NAT for a network that needs a 192.168.x.x private for a dhcp server and a few other VMs and I don't want it to leak out into the 10.10.x.x network. I need almost all machines in the 192.168.x.x to have internet connectivity and the gateway is on the 10.10.x.x. I have followed a few guides including the Cisco official NAT guide, I can ping all 10.10.x.x with my current config but can't ping in or get any sort of internet access. Here is my current config.
hostname owenrouter
boot-start-marker
boot-end-marker
enable password airsoft11
no aaa new-model
dot11 syslog
ip source-route
ip cef
no ip domain lookup
license udi pid CISCO2811 sn FTX1303A02C
redundancy
interface FastEthernet0/0
ip address 10.10.150.150 255.255.0.0
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.150.150 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
clock rate 2000000
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
end
5 Replies 5
Seb Rupik
If you devices in the 192.168.150.0/24 subnet can ping other devices in the outside subnet 10.10.0.0/16 then this shows NAT on the 2811 is working as intended.
You appear to be lacking a default route, which is preventing your NAT'd traffic from being routed off-subnet. Install a static route for the 10.10.0.0/8 subnet gateway and it will probably start working.
cheers,
Seb.
Hello
no access-list 100
access-list 100 permit ip 192.168.50.0 0.0.0.255 any
ip route 0.0.0.0 0.0.0.0 fa0/0 10.10.x.x
Kind Regards
Paul
Jaderson Pessoa
Your current configuration doesn't has a default route.
try it:
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0 (is best practice input the ip address as destination).
Jaderson Pessoa
*** Rate All Helpful Responses ***
Jaderson Pessoa
try it:
Jaderson Pessoa
Deepak Kumar
As all configuration looking ok but you are missing a default route configuration.
Note: As a best practice, we are choosing remote end IP address (ISP modem/ISP Gateway) instead of an interface but We don't you have any such information about your ISP devices so we are given example with an outside interface and it's ID.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
