4500x Multicast Routing
djbowling
Problem solved
6 Replies 6
Richard Burts
Not sure what the issue is. Here are a couple of things to check:
- what do you get as output if your enter ip ?
- can you verify that ip routing is enabled
- what output do you get for the commands show ip protocol and for show ip route
- what licenses/features do you have on this switch?
Rick
Rick
Yes it is. I have 4 of the 4500x as my network backbone and they are currently doing IP ROUTING.
IPBASE
IP BASE Support Multicast
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/release/note/OL_26674-01.pdf
what is the error you get when you issue that command ?
BB
%unrecognized command
Its like the command is not on the router at all...
The issue seems like you don't have required License activated. Share output "show license" command. This feature is required minimum IP BASE license.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
I asked 4 questions and you answered 2 of them, which I appreciate. Would you also provide these:
- what do you get when you enter ip ?
- what is the output for show ip protocol
- what is the output for show ip route
Rick
Rick
