Need help with routing Cisco 867vae-k9 with Public WAN and LAN IP Addresses
Sanga62
We recently changed our ISP but unfortunately they didn't provide any routing. So, i had a Cisco 867vae-k9 in spare.
My new ISP provided me Static WAN IP with DNS and Gateway and Static LAN IPs.
I tried several tutorials and i am unable to get it to work.
Can someone help me out to configure this router.
make sure your configuration looks exactly like the one below, line by line, character by character. When you are finished, post the configuration again so we can double check...
Building configuration...
Current configuration : 1862 bytes
version 15.2
no service pad
hostname Agile-Jio
boot-start-marker
boot-end-marker
enable secret 5 $1$iReF$.u/Yok6mUgHgSFi8nOlEn1
enable password XXXXXXXX
no aaa new-model
wan mode ethernet
ip routing
ip dhcp excluded-address 115.xxx.x.209
ip dhcp pool LAN
network 115.XXX.X.0 255.255.255.248
default-router 115.XXX.X.209
dns-server 8.8.8.8 8.8.4.4 49.45.0.1
no ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface ATM0
no ip address
no ip route-cache
shutdown
no atm ilmi-keepalive
interface Ethernet0
no ip address
no ip route-cache
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
description Uplink to ISP
ip address 136.xxx.xxx.206 255.255.255.252
ip mtu 1492
ip nat outside
ip virtual-reassembly in
no ip route-cache
duplex auto
speed auto
interface Vlan1
description LAN Interface
ip address 115.xxx.x.209 255.255.255.248
ip nat inside
no ip route-cache
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 10 interface GigabitEthernet1 overload
ip route 0.0.0.0 0.0.0.0 136.xxx.xxx.205
access-list 10 permit 115.241.1.0 0.0.0.7
line con 0
no modem enable
line aux 0
line vty 0 4
password XXXXXXXX
login
transport input all
scheduler allocate 60000 1000
end
13 Replies 13
below is a sample configuration:
Current configuration : 2041 bytes
! Last configuration change at 02:17:41 UTC Sat Feb 27 2016
version 15.2
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
hostname mrciscorouter
boot-start-marker
boot-end-marker
enable secret xxxxxxxxxxxxxxxxxxxx
enable password xxxxxxxxxxxx
no aaa new-model
wan mode ethernet
ip cef
no ipv6 cef
controller VDSL 0
shutdown
ip dhcp excluded-address 192.168.1.1
ip dhcp pool LAN
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
interface ATM0
no ip address
shutdown
interface Ethernet0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
shutdown
no ip address
no ip address
no ip address
no ip address
no ip address
ip address x.x.x.x y.y.y.y
ip mtu 1492
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip http server
ip dns server
ip route 0.0.0.0 0.0.0.0 GigabitEthernet1
access-list 10 permit 192.168.1.0 0.0.0.255
snmp-server community xxxxxxxxxxxxxxxxx
line con 0
no modem enable
line aux 0
line vty 0 4
password xxxxxxxxxxxxxxx
login
transport input all
end
Thank you very much for your reply, maybe i am a noob or maybe i didn't understood the example so let me provide you some more details.
Wan IP Details:
WAN IP: 136.xxx.xxx.xxx
GATEWAY IP: 136.xxx.xxx.xxx
SUB-NET MASK: 255.255.255.252
DNS:49.xx.xx.x
PUBLIC LAN IP:
LAN IP POOL : 115.xxx.x.xxx/29
Subnet: 255.255.255.248
115.xxx.x.xxx (Gateway)
Usable LAN IPs
115.xxx.x.xxx - For firewall
115.xxx.x.xxx - For Exchange Server
115.xxx.x.xxx - Chat Server
115.xxx.x.xxx - File Server
115.xxx.x.xxx - FTP Server
IF the info i provided makes any sense can you provide the configuration steps.
Also this is what i have done so far.
Current configuration : 1501 bytes
! Last configuration change at 16:27:54 UTC Thu Dec 12 2019
version 15.2
no service pad
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
wan mode ethernet
ip dhcp pool LAN
 network 115.xxx.1.0 255.255.255.0
 default-router 115.xxx.1.209
ip cef
no ipv6 cef
controller VDSL 0
 shutdown
interface ATM0
 no ip address
 shutdown
interface Ethernet0
 no ip address
 shutdown
 no ip address
 no ip address
 no ip address
 no ip address
 no ip address
 ip address 136.xxx.xxx.xxx 255.255.255.252
 ip mtu 1492
 shutdown
 duplex auto
 speed auto
interface Vlan1
 ip address 115.xxx.x.xxx 255.255.255.248
 ip nat inside
no ip http server
ip dns server
access-list 10 permit 115.xx.1.0 0.0.0.248
mac-address-table aging-time 15
line con 0
 no modem enable
line aux 0
line vty 0 4
 login
 transport input all
end
Still cant get it to work.
Here are some info provided to me by ISP.
Wan IP Details:
DNS:49.xx.xx.x
PUBLIC LAN IP:
115.xxx.x.209 (Gateway)
Usable LAN IPs
Here is my Current Configuration
Current configuration : 1880 bytes
! Last configuration change at 18:18:36 UTC Thu Dec 12 2019
version 15.2
no service pad
hostname Agile-Jio
boot-start-marker
boot-end-marker
no aaa new-model
wan mode ethernet
no ip routing
ip dhcp pool LAN
network 115.xxx.x.0 255.255.255.248
default-router 115.xxx.x.209
no ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface ATM0
no ip address
no ip route-cache
shutdown
interface Ethernet0
no ip address
no ip route-cache
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip mtu 1492
ip nat outside
no ip route-cache
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip route-cache
shutdown
ip default-gateway 136.xxx.xxx.205
no ip http server
ip dns server
access-list 10 permit 115.xxx.x.0 0.0.0.252
dialer-list 1 protocol ip permit
line con 0
no modem enable
line aux 0
line vty 0 4
password XXXXXX
login
transport input all
end
your access list 10 is wrong. It needs to be:
access-list 10 permit 115.xxx.x.0 0.0.0.7
Thanks Again for your reply.
I am still unable to get the internet running.
Here are the Details from My ISP.
WAN Details From ISP:
WAN IP: 136.xxx.xxx.206
GATEWAY IP: 136.xxx.xxx.205
DNS:49.xx.xx.1
I want to use above mentioned IP to setup internet Connection.
Question: How do we enter Default gateway and Dns for interface "GigabitEthernet1"
LAN IP Pool provided by IP.
IP1: 115.XXX.X.209 Need to use this IP for gateway for below mentioned LAN IPs.
IP2: 115.XXX.X.210 Need to assign to a Client PC on network behind router.
IP3: 115.XXX.X.211 Need to assign to a Client PC on network behind router.
IP4: 115.XXX.X.212 Need to assign to a Client PC on network behind router.
IP5: 115.XXX.X.213 Need to assign to a Client PC on network behind router.
IP6: 115.XXX.X.214 Need to assign to a Client PC on network behind router.
Subnet Mask: 255.255.255.248
Then i guess we'll need NAT between WAN IP and LAN IPs
I am sorry i am new to Cisco configuration so bear with me.
can you ping 8.8.8.8 from the router ? Post the config with the real IP addresses...
Unable to Ping 8.8.8.8
Config is as below:
Agile-Jio#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Agile-Jio#sh run
version 15.2
no service pad
hostname Agile-Jio
boot-start-marker
boot-end-marker
no aaa new-model
wan mode ethernet
no ip routing
ip dhcp pool LAN
no ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface ATM0
no ip address
no ip route-cache
shutdown
interface Ethernet0
no ip address
no ip route-cache
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
no ip address
shutdown
ip mtu 1492
ip nat outside
no ip route-cache
shutdown
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip route-cache
shutdown
no ip http server
ip dns server
access-list 10 permit 115.241.1.0 0.0.0.252
line con 0
no modem enable
line aux 0
line vty 0 4
password XXXXXXXX
login
transport input all
end
Post the running configuration again. You have misconfigured access list 10 twice, we need to check if you got it right now...
Can you correct the things in my Config that i posted then I'll reset the router and rewrite the configuration.
version 15.2
no service pad
hostname Agile-Jio
boot-start-marker
boot-end-marker
no aaa new-model
wan mode ethernet
ip routing
ip dhcp pool LAN
no ip cef
no ipv6 cef
controller VDSL 0
shutdown
interface ATM0
no ip address
no ip route-cache
shutdown
interface Ethernet0
no ip address
no ip route-cache
no ip address
no ip address
no ip address
no ip address
no ip address
ip mtu 1492
ip nat outside
no ip route-cache
duplex auto
speed auto
interface Vlan1
ip nat inside
no ip route-cache
no ip http server
line con 0
no modem enable
line aux 0
line vty 0 4
password XXXXXXXX
login
transport input all
end
Sir,
You are a Life and Job Saver.
Thank You Very Much for Your Assist and your time.
Would you mind if i bother you again in future if i get into any trouble with this router.
I can't thank you enough.
All is working fine all the IPs and Everything
Thanks Again
Have a wonderful day ahead.
glad that it is working. Post in the forum anytime you need assistance...
Both your GigabitEthernet1 and Vlan1 interfaces are at the shutdown status you should configure "no shut". Your network command under the "ip dhcp pool LAN" should read "network 115.XXX.X.208 255.255.255.248" and also your "access-list 10" should read "access-list 10 permit 115.241.1.208 0.0.0.7" and not "access-list 10 permit 115.241.1.0 0.0.0.7" as advised.
Good Luck!
Best regards,
Antonin
